You need to buy 2 silencer too with you use 5/2 (the gold piece at Rodw video)
Your cylinder model dont have cushion just bumper optional with no cost but you need too choose it. If you buy speed controler you dont wear your cylinder and reduce the noise at the end of stroke. I think you dont need full stroke so just 1 speed controller for the retract side is fine IMO but im always use 2 because customer requisite
You can use the 2/2 but need another 2 and need 3 output to control it using logic and at least one sensor to know the stroke position (5/2 is more easy because you dont know yet to program)
www.bimba.com/sites/default/files/Librar..._Pneumatic_Bimba.pdf
CKD solenoid valve is nice too if you can find it, you can abuse it a lot. SMC for manifold i like.
pneumatic we use CKD and SMC, Hydraulic Tayo/Parker.
