using linuxcnc for laser fiber marking
14 Oct 2021 11:14 #223073
Replied by andypugh on topic using linuxcnc for laser fiber marking
My impression is that the squares are good, so G1 moves are working correctly at the feed rate that you are using.
So the issue seems to be with the G0 moves.
As a first step, try reducing the MAX_VELOCITY in the INI to closer to the same speed as the feed rate in the video. Then if that fixes the lossof position problem, increase it until the issue re-appears, Then back off slightly.
Galvos should be very repeatable, you don't need to worry about part mass, so you don't need much spare capability.
- Thank you received: 5330
14 Oct 2021 18:50 #223105
Replied by PCW on topic using linuxcnc for laser fiber marking
First comment out this line
setp hm2_5i25.0.xy2mod.write-timer-number 1
Then set all PID P values to 2000
Then set a reasonable acceleration value
(you cannot set it to an unachievable value,
this guarantees overshoot in the galvanometer)
MAX_ACCELERATION = 9999999999999999999 Will not work
Then when you are getting closer to tuning you need to add a little bit of FF2
(say around 0.0005 but this needs to be tuned)
You tune with halscope (plotting velocity and following error)
The following user(s) said Thank You: mahdi2001h
- mahdi2001h
17 Oct 2021 06:41 #223362
by mahdi2001h
Replied by mahdi2001h on topic using linuxcnc for laser fiber marking
Thanks to PCW , your answer was very helpful .
My system is much more stable now.
Time to create page: 0.092 seconds
