Difficulties in probing
13 Oct 2021 19:28 #223037 by Jflesburg
Replied by Jflesburg on topic Difficulties in probing
That’s what I thought. Thanks for confirming. It does transition to a slower speed when the float switch trips. I’ll post a backup config when I get home from work.
Thanks for replying!
13 Oct 2021 23:07 #223043 by Jflesburg
I have attached a backup of my configuration, so hopefully this will be helpful in finding my problem.
Thanks in advance!
File Name: john_001_v...8.tar.gz
File Size:11 KB
13 Oct 2021 23:08 #223044 by snowgoer540
Replied by snowgoer540 on topic Difficulties in probing
Any chance for some video?
13 Oct 2021 23:11 #223045 by Jflesburg
That would be really tricky at this point. If the configuration doesn't help, I'll have to figure out how to record and post a short video.
14 Oct 2021 13:53 #223085 by snowgoer540
I cant visualize your Z axis setup, so pictures would do, video is not strictly necessary.
At any rate, here is what I see:
You are using hm2_7i96.0.gpio.001.in for both max-z and float-switch. I cant visualize how you could be using the same switch for both functions, so this doesn't seem right to me. I am fairly certain this is the source of your probing angst.
For your ini file, in the [AXIS_Z] section, your MAX_ACCELERATION should be 1500.0 and not 1000.0 (it needs to be double the value of the corresponding joint. Similarly, in the [JOINT_3] section, your STEPGEN_MAXACCEL should be 937.5 instead of 950.0 (assuming you didn't have it set that way to negate some sort of following errors, etc).
  • Moderator
  • Moderator
14 Oct 2021 15:44 #223089 by tommylight
Replied by tommylight on topic Difficulties in probing
Yeah, the question now becomes: do you actually have a floating head with it's separate switch?
14 Oct 2021 15:46 #223090 by snowgoer540
Precisely.  So hopefully he can provide us some pics/more insight.
14 Oct 2021 17:14 #223097 by Jflesburg
# external input signals
# --- HOME-Z ---
net home-z     <=  hm2_7i96.0.gpio.000.in
# --- MAX-Z ---
# net max-z     <=  hm2_7i96.0.gpio.001.in
# --- HOME-Y ---
net home-y     <=  hm2_7i96.0.gpio.002.in
# --- MAX-Y ---
net max-y     <=  hm2_7i96.0.gpio.003.in
# --- HOME-X ---
net home-x     <=  hm2_7i96.0.gpio.004.in
# --- MAX-X ---
net max-x     <=  hm2_7i96.0.gpio.005.in
# --- HOME-X2 ---
net home-x2     <=  hm2_7i96.0.gpio.006.in
# --- MAX-X2 ---
net max-x2     <=  hm2_7i96.0.gpio.007.in
I thought that I had commented out the max-z. (which is how I had initially set it up in the pncconfig, but plasmac complained about this at startup)  Is this in a different location as well?
Noted on the accelerations which I corrected last night while still trying to figure it out.
If nothing else, tonight I might try starting over with a fresh pncconfig without a z-max limit switch.
I didn't intend on using both.
Thank you all for your help.
14 Oct 2021 17:40 - 14 Oct 2021 17:40 #223099 by snowgoer540
# --- HOME-Z ---
# --- MAX-Z ---
# --- HOME-Y ---
# --- MAX-Y ---
# --- HOME-X ---
# --- MAX-X ---
# --- HOME-X2 ---
# --- MAX-X2 ---
Whoops, I looked at this quickly on break at work, apparently too quickly. You are correct, Z was commented out.
I am still not picturing what you have for a probing/z axis setup. Is it possible for you to share pictures or not? It's unclear if you have a floating head, or what you have going on. Without that, it's difficult to help you further.
Last edit: 14 Oct 2021 17:40 by snowgoer540.
15 Oct 2021 00:35 #223136 by Jflesburg
File Name: MyMovie2_2...0-14.zip
File Size:1,093 KB
Trying to attach a short video.  You can hear the change in speed when the float switch trips.  I'm planning on making a fresh configuration (without trying to put a z-max limit.  Wondering if commenting it out afterward didn't actually cause problems.
Time to create page: 0.415 seconds
