Difficulties in probing
- Clive S
- Thank you received: 486
15 Oct 2021 10:50 #223192
by Clive S
Replied by Clive S on topic Difficulties in probing
- snowgoer540
- Thank you received: 907
15 Oct 2021 10:56 - 15 Oct 2021 10:56 #223193
by snowgoer540
Haha, perhaps. Though in all honesty, I've never been that great at fixing configs just by looking at them. I learn just long enough to forget it the next time someone else has an issue
Maybe I'll start a list of things to check...
Replied by snowgoer540 on topic Difficulties in probing
I think you are slipping a bit
Last edit: 15 Oct 2021 10:56 by snowgoer540.
- Thank you received: 4149
15 Oct 2021 16:59 #223213
Replied by rodw on topic Difficulties in probing
Thats quite a good diagram, thanks for adding it to the docs.Yes it is a bit backwards.
You need have AXIS_Z MAX LIMIT and JOINT_3 MAX_LIMIT the same 70? (or 100)?
set the following JOINT_3 paramaters:
STEP_SCALE = -200.0 (negative will reverse the motor direction so it is correct)
HOME = 65 (or 95)
HOME_OFFSET = (72 or 102)
HOME_SEARCH_VEL = 20.000000
HOME_LATCH_VEL = 1.000000
HOME_FINAL_VEL = 10.000000
EDIT: Here is a diagram of a Z axis (we should add it to the PlasmaC docs):
linuxcnc.org/docs/devel/html/plasma/qtpl...tml#qt_initial-setup
Time to create page: 0.331 seconds
