- Thank you received: 2349
Post Processor for LinuxCNC and PlasmaC
- Grotius
7 years 4 months ago #136609
by Grotius
Replied by Grotius on topic Post Processor for LinuxCNC and PlasmaC
@Rod,
I might add that if I could also get Linuxcnc to calculate the arc radius, there would be no need to ever use sheetcam code snippets....
You give me an idea to change colors in openGL.
github.com/LinuxCNC/linuxcnc/blob/master...hon/rs274/glcanon.py
- islander261
- Thank you received: 216
7 years 4 months ago #136615
by islander261
Replied by islander261 on topic Post Processor for LinuxCNC and PlasmaC
Guys
You can control the THC enable from Gcode now using the correct code in your postgui.hal file to unlink the pins. You can even have the material file THC enabled and then drive from Gcode if desired, the only catch is you always have to drive from Gcode. Rod's adaptive feed is a little harder, the easiest way will be to use a digital pin pin to select control from Gcode and an analog pin to set the adaptive feed rate. I know how to do it by just looking at the adaptive feed signal from Gcode but can't even begin figure out how to convey the process to a new user who doesn't understand how the .hal works or the PP for their CAM. I think the question here is does Phill want the Plasmac branch to be the all singing and dancing job shop cnc plasma solution or is it for the new hobby user that has little understanding of cnc plasma cutting and even less of how to setup a post processor to work with their needed CAM solution. I think right now it is a compromise, the material tables make it easy for the newbie and hand coder while the being able to select the material from Gcode allows more advanced users the control they need at the expense of more material entries in the tables. Material table size should be a non issue for any controller capable running LinuxCNC.
'03
I believe in the past you said you had a CommandCNC controller. If I am to believe the adverts and T.C.'s BS it is the solution you are looking for. Remember CommandCNC is just a Gscreen app and can be adapted to use the plasmac component for Z axis control with little effort. From my previous adaptation of it to my THC it should take about 20 hours of coding and testing to make it work. Please post your CommandCNC .ini and .hal files. I would like to see how nice a job the proprietary configuration program does.
Phill
The THC enable entry in CandCNC's SheetCam post is to control the global enable of the THC hardware. It is checked at the start of each G1 block to synch the THC state machine. This works because the first move at the end of the pierce is always a G1 Z to the cut height and all later ones are at the same height. The PP to do all this plus support any tool you might hang on your Z axis is quite complex and not very robust.
A built in way to enable/disable the THC from Gcode is a nice feature for advanced users. The question then becomes is it done on a cut by cut basis or at any time in the cut? I think that the default for the feature needs to be no Gcode control to function automatically follows the material table entries.
I think it will be wise to leave the generation of material/cutting tables to the user. Anyone that has enough knowledge to use advanced features knows how to do test cuts to confirm cutting parameters. There is no way to anticipate all the hardware combinations that may be used in the field.
'03
Phill
- islander261
7 years 4 months ago #136662
by islander261
Guys
As promised please find attached a minimal SheetCam PP for the plasmac branch. This PP requires matching SheetCam tool numbers and Plasmac material table numbers. Only the data from the Plasmac material table is actually used for cutting parameters. This PP will not insert random feed rate words or Z motion.
The Gcode file made by this PP has one SheetCam " feature" that I don't know how to defeat. At every tool change an extra G0 block that points to the current location will be put in the code. This is hard coded in the SheetCam tool change code because it is not effected by the modal state of the code. This will have no practical effect because the torch is already at that position and isn't cutting at the time.
Please test carefully on your system before use. I cut several sheets with tool changes but certainly didn't get to every possible corner condition. The file is ready to use once you strip the .txt extension off of the file name
- thefabricator03
- Visitor
7 years 4 months ago #136683
by thefabricator03
John, Please see attached.
Replied by thefabricator03 on topic Post Processor for LinuxCNC and PlasmaC
- islander261
7 years 4 months ago #136685
by islander261
'03
Thank you, Moses does nice work. I had to reverse engineer mine, first the sim then a working one.
- Thank you received: 4153
7 years 4 months ago #137182
Replied by rodw on topic Post Processor for LinuxCNC and PlasmaC
I've swapped some emails with Les at Sheetcam and have sent Phill some example output just to make sure its doing the right thing. In the mean time, here is a screen dump of some sheetcam cutting rules by SeanP that Islander261 has mentioned.
plasmaspider.com/viewtopic.php?f=114&t=25142&p=154172#p154172
Here is what we are generating when cutting a hole.
So as long as I confirm thats what we are meant to do, I'll explain how to do this and we'll replicate Sean's rules the plasmac way. Its not something you can package up and install, you will need to make your own rules.
M3 S69
G1 Y2.850
M67 E3 Q70 (70% of cut speed)
G2 I0.000 J1.650
M67 E3 Q0 (100% of cut speed)
M5
Time to create page: 0.162 seconds
