Opening folders and list of materials does not work
- phillc54
- Thank you received: 2100
24 Aug 2019 12:55 #143089
by phillc54
Replied by phillc54 on topic Opening folders and list of materials does not work
It probably sounds silly but have you tried rebooting the machine.
The following user(s) said Thank You: KRAD-AT
- KRAD-AT
24 Aug 2019 13:09 #143090
by KRAD-AT
Replied by KRAD-AT on topic Opening folders and list of materials does not work
Yes I did multiple times. It's strange since the other config does work properly.
Thank you for your help!
- thefabricator03
- Visitor
25 Aug 2019 08:36 #143123
by thefabricator03
Replied by thefabricator03 on topic Opening folders and list of materials does not work
I have this problem, When you select a folder press the Enter key on your keyboard to open the folder,
I thought it must be some kind of design feature for Axis.
- KRAD-AT
25 Aug 2019 14:20 #143146
by KRAD-AT
You are right. I just tested it and using the enter key works but it is still a strange bug. However i can test it now.
- KRAD-AT
25 Aug 2019 17:17 #143151
by KRAD-AT
Once again i ran into a problem with Plasmac.
I set up the limits and homing for my zaxis but probing does not work.
It probes in the wrong direction. Homing works perfect but it probes upwards not down.
What could be wrong?
- Thank you received: 7478
25 Aug 2019 18:02 #143153
Replied by tommylight on topic Opening folders and list of materials does not work
Did you try to set the probing speed to a negative value ?
- KRAD-AT
25 Aug 2019 19:03 #143161
by KRAD-AT
Yes but it seems to ignore it.
Maybe negative numbers are not allowed for this value.
25 Aug 2019 19:06 #143162
When you press pg_down for jogging, does the Z axis move down ?
- KRAD-AT
25 Aug 2019 19:14 #143163
by KRAD-AT
yes it does. auto homing also works.
25 Aug 2019 19:25 #143164
Strange..... out of ideas for now.
Time to create page: 0.797 seconds
