Opening folders and list of materials does not work
- KRAD-AT
24 Aug 2019 10:37 #143076
by KRAD-AT
Opening folders and list of materials does not work was created by KRAD-AT
Hello Plasmac Experts!
Today I upgraded my machine from wheezy 2.7 to the current master 2.9 and added auto squaring funtionality.
This worked well. I have a working config for plasma now.
After that I tried to get Plasmac working and ran into 2 Problems:
1) I made an material file using martialverter but it doesn't show up in the software.
2)When I try to open a nc file via the icon or the dropdown menu the usual window pops up but i cant open the folders i see.
Has anyone had the problem before and can maybe help me?
Thank you in advance from sunny Austria!
Cheers,
Martin
Cheers,
Martin
- phillc54
- Thank you received: 2100
24 Aug 2019 10:57 #143077
by phillc54
Replied by phillc54 on topic Opening folders and list of materials does not work
The material file needs to be in your configuration directory and needs to be named <machine_name>_material.cfg
I vaguely remember a problem similar opening directories but not sure what it was. If it comes to me I'll let you know.
Did you do a buildbot installation or is it run in place?
- Thank you received: 7488
24 Aug 2019 10:59 #143078
Replied by tommylight on topic Opening folders and list of materials does not work
Hallo Martin,
By nc files you mean ngc files, or?
Normaly the nc files will not be visible so you have to select ALL at the botom right for file types where it says ngc files.
If you can not open folders, that is something i never encountered so i can not help.
As for the material issue that should have been already fixed by PhillC as i recal reading about it in the "another plasma component" topic here
forum.linuxcnc.org/plasma-laser/35449-an...nt?start=1630#143075
That is a long thread but it should be in the last 10 pages or so.
MFG
Tom.
MFG
Tom.
- KRAD-AT
24 Aug 2019 11:08 - 24 Aug 2019 11:15 #143080
by KRAD-AT
The file is in the right directory and named right. Is it possible that linuxcnc needs special right for the file to work with it?
I did a buildbot install.
The folder problem is especially interesting because on the same machine with the old config everything seems to work fine.
Replied by KRAD-AT on topic Opening folders and list of materials does not work
Last edit: 24 Aug 2019 11:15 by KRAD-AT.
- phillc54
24 Aug 2019 11:15 #143081
by phillc54
Normal user permissions are all that is required.
If you are opening LinuxCNC from a terminal you should get an error if it cannot open the file.
Are you using Axis or Gmoccapy.
- KRAD-AT
24 Aug 2019 11:59 #143083
by KRAD-AT
Im using axis
- phillc54
24 Aug 2019 12:04 #143085
by phillc54
Could you zip your configuration directory and post it.
- KRAD-AT
24 Aug 2019 12:23 - 24 Aug 2019 12:27 #143086
by KRAD-AT
Here it is
Thank you all for your help so far!
Last edit: 24 Aug 2019 12:27 by KRAD-AT.
- phillc54
24 Aug 2019 12:47 #143087
by phillc54
I can't test as I'm only on my phone at the moment. Can you try replacing the comma in Pierce Height with a . and see if that fixes it.
- KRAD-AT
24 Aug 2019 12:51 #143088
by KRAD-AT
@phillc54: You are great!! That was the Solution for the material problem.
Thank you so much.
Now i just have to solve the folder problem.
Thank you so much.
Time to create page: 0.142 seconds
