Opening folders and list of materials does not work
- Thank you received: 4149
27 Aug 2019 04:25 #143274
Replied by rodw on topic Opening folders and list of materials does not work
Gee, I wish I had a Phill around when I set up my machine. I had to work out all my stuffups the hard way on my own!
- phillc54
- Thank you received: 2100
27 Aug 2019 04:29 #143275
by phillc54
Hey Rod I meant to tell you that a good place to keep your custom HAL stuff is the connections.hal file as that doesn't get overwritten by the configurator.
Replied by phillc54 on topic Opening folders and list of materials does not work
HaHa, me too.Gee, I wish I had a Phill around when I set up my machine. I had to work out all my stuffups the hard way on my own!
27 Aug 2019 05:14 #143278
Thanks Phill, but that does not work for me as I already use half a dozen pins Plasmac claims So I need to unwind what I have done and use the plasmac pins. I'll do it one day.
- phillc54
27 Aug 2019 05:17 #143280
by phillc54
No worries, if you want a hand yell out.
- thefabricator03
- Visitor
28 Aug 2019 07:38 - 28 Aug 2019 07:38 #143408
by thefabricator03
Phill,
I am not a programmer but I am trying to learn a bit so I can get some robotic software developed,
How did you find out that adding the above line of code to the ini file would solve our problem with browsing files through AXIS's file menu?
Also can we add that line to future PlasmaC Axis releases?
Replied by thefabricator03 on topic Opening folders and list of materials does not work
For you Guys having a problem opening files in the Axis GUI the following entry in your INI file in the [DISPLAY] section should fix it:
CYCLE_TIME = 0.05
Phill,
Last edit: 28 Aug 2019 07:38 by thefabricator03.
- phillc54
28 Aug 2019 07:46 #143411
by phillc54
When i did the config for KRAD_AT I went through line by line with a sim config to note the differences and saw that in his config the CYCLE_TIME was missing. I then went through the Axis source code and saw the default was 0.02 seconds. I tried different numbers and it was consistently working at 0.04 so 0.05 should be safe. I do all mine at 0.10 and it seems OK. I Tried a non PlasmaC sim and it worked at 0.02 so I guess with all the add ons to Axis it slows it down a bit. Gmoccapy default to 0.15 so it's still quicker than that.
Yes, I have already added it for new installs.
BTW did it fix it for you.
The following user(s) said Thank You: tommylight, thefabricator03
- thefabricator03
- Visitor
28 Aug 2019 08:53 #143417
by thefabricator03
Yes it did, Thank you
- phillc54
28 Aug 2019 08:57 #143419
by phillc54
I have managed to get the Pierce/Cut buttons working on Gmoccapy like they do on Axis. There is a difference in that when a new program is loaded it resets back to Pierce & Cut mode regardless of where it was. I would like to do the same on Axis so it keeps the code and documentation similar. Is that a problem for you if I do that?
Next question.Yes it did, Thank you
- thefabricator03
- Visitor
28 Aug 2019 09:03 #143421
by thefabricator03
What do you mean by it resets back to pierce and cut mode? Are you saying when I load a program it loads into pierce and cut mode? If that is the case it would be a problem for me with my guys using the machine. I try to dumb down the operation so they understand it as much as possible and if they were to load a program and it is default in pierce and cut mode they would probably run the program the way it was loaded, Most jobs I do are under 16mm so I dont really need it to be the default.
- phillc54
28 Aug 2019 09:07 - 28 Aug 2019 09:20 #143422
by phillc54
Pierce & Cut is the standard mode.
Pierce Only is when the button is orange.
EDIT: See what it does here when it loads a new program.
Last edit: 28 Aug 2019 09:20 by phillc54.
Time to create page: 2.353 seconds
