- Thank you received: 25
That seems odd, what does the Arc Voltage display?docwelch wrote: With the plasmac.comp Phill posted earlier:
With torch on time set to 77 (cut volts is 78 and use auto volts is disabled) - the torch never fires. Air flows and the Torch On button briefly lights.
