Center Spot Sheetcam Post
- thefabricator03
- Visitor
11 Sep 2019 18:44 - 11 Sep 2019 18:45 #144844
by thefabricator03
Center Spot Sheetcam Post was created by thefabricator03
Phill,
Do you have a center spot post processor for Sheetcam you could share? Or can we just select a drill tool in sheetcam and it will do the same thing? I guess we wont be able to use the PlasmaC built in function if we do that.
Do we need to create a tool to use the spot function like we did for the scribe? If so what parameter do we need to set?
Last edit: 11 Sep 2019 18:45 by thefabricator03.
- phillc54
- Thank you received: 2100
11 Sep 2019 18:51 - 11 Sep 2019 18:54 #144846
by phillc54
Replied by phillc54 on topic Center Spot Sheetcam Post
Here you go, I think it is the same as the last one I posted.
You need either of Centre Spot or Center Spot somewhere in the tool name.
Probably have Pierce Height and Cut Height the same.
THC = disabled
Pierce Delay = 0
Cut Rate = really fast
EDIT: You also need to set the Torch On Time in the Config Panel
THC = disabled
Pierce Delay = 0
Last edit: 11 Sep 2019 18:54 by phillc54.
- thefabricator03
- Visitor
11 Sep 2019 19:06 - 11 Sep 2019 19:08 #144848
by thefabricator03
Replied by thefabricator03 on topic Center Spot Sheetcam Post
So in sheetcam can I set the spot up as a drill tool? As long as I am selecting the correct center spot tool?
Last edit: 11 Sep 2019 19:08 by thefabricator03.
- phillc54
11 Sep 2019 19:20 #144850
by phillc54
I am not sure, I don't know what a drill tool is or does. I think I had it as a plasma tool.
- thefabricator03
- Visitor
11 Sep 2019 19:24 #144851
by thefabricator03
Ill try drill tool and see how it goes.
- thefabricator03
- Visitor
11 Sep 2019 19:43 - 11 Sep 2019 19:49 #144853
by thefabricator03
Hit a bit of a snag updating my run in place config,
Usually I when I get that error I do git reset --hard and it works but not this time,
Any ideas Phil?
Any ideas Phil?
Last edit: 11 Sep 2019 19:49 by thefabricator03.
- phillc54
11 Sep 2019 19:53 #144854
by phillc54
It looks like you have used the Sims and saved config changes.
If you don't need them do
git checkout .Please Log in or Create an account to join the conversation.
- thefabricator03
- Visitor
11 Sep 2019 20:01 #144855
by thefabricator03
Did not work,
What next?
What next?
- phillc54
11 Sep 2019 20:04 #144856
by phillc54
Did you leave out the space dot after checkout.
I am on my phone and can't see clearly
- thefabricator03
- Visitor
11 Sep 2019 20:05 #144857
by thefabricator03
I did but when back and did it again and still no luck.
Time to create page: 1.801 seconds
