Center Spot Sheetcam Post
- phillc54
- Thank you received: 2100
12 Sep 2019 06:02 #144918
by phillc54
Replied by phillc54 on topic Center Spot Sheetcam Post
This has a 3 second delay after each spot.When it was moving to the next peck. I hit stop and selected the line going to the peck and right clicked the gcode and ran from line.
- Thank you received: 4149
12 Sep 2019 06:17 #144919
This has no probing at the spots (eg no Z axis motion) and no torch firing even at 999 ms. So what am I missing in the config if spindle 2 is not turning on?
Replied by rodw on topic Center Spot Sheetcam Post
- phillc54
12 Sep 2019 06:21 - 12 Sep 2019 06:24 #144920
by phillc54
[TRAJ]
SPINDLES = 2 ?
EDIT: 3 would be better
EDIT2: and setp plasmac.multi-tool 1 in _connections.hal
SPINDLES = 2 ?
Last edit: 12 Sep 2019 06:24 by phillc54.
- thefabricator03
- Visitor
12 Sep 2019 06:33 #144921
by thefabricator03
No luck Phill, I slowed down the Z axis and still not working,
Replied by thefabricator03 on topic Center Spot Sheetcam Post
- phillc54
12 Sep 2019 06:38 #144922
by phillc54
It is odd that it did #1 & #3 but not #2 or #4...
Just change the G4 P3 lines to say G4 P5 and see if that makes a difference. There are five of them.
- thefabricator03
- Visitor
12 Sep 2019 06:57 #144923
by thefabricator03
No luck Phill,
Same thing happened. I see the torch on light coming on so its trying to tell the plasma to fire, I am not sure why it does not fire though. Its not like is it happening too fast for the plasma to be able to fire.
- phillc54
12 Sep 2019 06:59 #144924
by phillc54
OK then try something silly like G4 P10 that should at least eliminate the delay as the problem.
You did reload the GCode file after editing?
- thefabricator03
- Visitor
12 Sep 2019 07:10 #144925
by thefabricator03
OK tried G4 P10, no luck,
And yes I made sure I could see that code in the Axis gcode display.
- phillc54
12 Sep 2019 07:14 #144926
by phillc54
Was the behaviour the same, do #1 & #3 miss #2 & #4.
It doesn't make any sense to me.
Does your relay have a light to show it is doing something? (although the pulse is probably a bit quick)
12 Sep 2019 07:15 #144927
Ok, guys, I worked it out I think!
There is a deliberate delay in the plasma machine to allow gas to flow. After removing the 3 second delay, I got reliable spotting at 220 ms but not at 200 ms.
At one stage when being too fast (maybe 150ms), I could see the air start to flow on the first pierce which missed firing and then the second hole fired becasue the gas was flowing!
So I think Phill is kinda right. You need to wait until the arc fires say > 20 volts or something and then count down the delay then turn off.
At 220 Ms, it was not as fine as I was hoping for but better than waiting for an ArcOK. the 2mm sheet was just pierced with a pin prick. But I need to edit the file becasue it is selecting Stefan's settings which was 6mm steel on my machine and I was cutting 2mm..
Time to create page: 0.108 seconds
