Center Spot Sheetcam Post
12 Sep 2019 00:40 #144907 by phillc54
Replied by phillc54 on topic Center Spot Sheetcam Post
I got it to work for my job by stopping and starting the program at each point
You mean in the GCode or manually, if GCode could you post that or if manually could you describe it a bit more.
  • thefabricator03
  • thefabricator03's Avatar Topic Author
  • Visitor
  • Visitor
12 Sep 2019 00:41 #144908 by thefabricator03
Replied by thefabricator03 on topic Center Spot Sheetcam Post
After the peck I stopped the program and then selected run from line.
12 Sep 2019 00:43 #144910 by phillc54
Would it be worth trying a dwell (G4) after each peck then?
  • thefabricator03
  • Visitor
  • Visitor
12 Sep 2019 00:45 #144911 by thefabricator03
It would be worth a try, If you could modify the g-code file I can test that out.
12 Sep 2019 00:47 #144912 by rodw
Replied by rodw on topic Center Spot Sheetcam Post
From what I can gather the 'good' side of the cut is the right hand side so for inside cuts go anti-clockwise and outside go clockwise.
What sort of relay do you use for the torch on.
This varies by machine. On mine it says "Viewed along the direction of travel, the right side of the cut is more square than the left. So this means as Phill said, I go clockwise on outside cuts. I think Sheetcam has a setting to Reverse Direction somewhere.
12 Sep 2019 00:48 #144913 by rodw
Stefan, are you using the file Phill uploaded?
12 Sep 2019 00:49 #144914 by phillc54
I will modify the code you sent earlier.
When exactly did you hit stop.
  • thefabricator03
  • Visitor
  • Visitor
12 Sep 2019 00:52 #144915 by thefabricator03
When it was moving to the next peck. I hit stop and selected the line going to the peck and right clicked the gcode and ran from line.
  • thefabricator03
  • Visitor
  • Visitor
12 Sep 2019 00:53 - 12 Sep 2019 00:53 #144916 by thefabricator03
Yeah I am using the post processor he posted earlier today.
Edit in the second post.
Last edit: 12 Sep 2019 00:53 by thefabricator03.
12 Sep 2019 00:57 #144917 by phillc54
Do some machines require a delay time between torch on signals?
Time to create page: 0.272 seconds
