PlasmaC Will Not Activate Torch Pin on My 7i96
  • MakingStuff
  • MakingStuff's Avatar Topic Author
  • Premium Member
  • Premium Member
23 Sep 2019 21:47 #146019 by MakingStuff
Hello everyone. I originally posted this in the Laser & Plasma section and then realized that it should have been posted here instead. Sorry for any confusion.
I can't seem to get the torch Output pins to close on my PlasmaC configuration. I have made sure that multiple tools are not enabled. When I enter M3 S1 from the MDI tab, the output pins remain open. I also tried M3 $0 S1 and that does not work either. I have my hal file set to "net plasmac:torch-on => hm2_7i96.0.ssr.00.out-00". I tried this on my base machine for coolant flood and it works there when I enter M8, the pins close. Am I missing something or doing something wrong?
23 Sep 2019 21:53 #146020 by phillc54
Replied by phillc54 on topic PlasmaC Will Not Activate Torch Pin on My 7i96
You won't get the torch to fire from MDI as PlasmaC will not be in the correct mode because it has not completed probing and moved to Pierce Height.
If you want to test the torch, use the Torch Pulse button in the GUI.
  • MakingStuff
  • Premium Member
  • Premium Member
24 Sep 2019 07:16 #146058 by MakingStuff
Replied by MakingStuff on topic PlasmaC Will Not Activate Torch Pin on My 7i96
Probe Test just moves the Z axis down until the float switch engages, then throws an error on the screen. If I raise the z-axis a little bit so the float switch does not engage, the z-axis moves down then back up to 0. The torch pins never close.
24 Sep 2019 07:20 #146059 by phillc54
What does the error say.
Probe test won't fire the torch, you need the Torch Pulse.
What GUI are you using?
  • MakingStuff
  • Premium Member
  • Premium Member
24 Sep 2019 07:33 #146061 by MakingStuff
Sorry about that. I read your message and fell asleep, then went out to the shop after I woke up and tried Probe Test instead of Torch Pulse.
I went back out to the shop and Torch Pulse worked. Thanks!
FYI the error on Probe Test was Float Switch Engaged While Traveling to Pierce Height. I'm not worried about that error right now. I'm still hooking up the machine right now.
24 Sep 2019 07:40 #146064 by phillc54
You may have a bit of bounce in the float switch.
The error indicates that there was a successful probe then the float switch activated again while moving up from the top of the material to the Pierce Height.
  • MakingStuff
  • Premium Member
  • Premium Member
24 Sep 2019 12:22 #146097 by MakingStuff
Ok, thanks for the heads up. I'll check it out and make sure there is no bounce.
13 Jan 2021 21:38 #195281 by Nick7251
Replied by Nick7251 on topic PlasmaC Will Not Activate Torch Pin on My 7i96
Bringing this topic back to life. I cannot get my 7i96 to fire the torch either. I have it connected to net plasmac:torch-on => hm2_7i96.0.ssr.00.out-00 in the HAL file, and also physically to that pin. When I watch the HAL Meter while pushing the Torch Pulse button, it just stays FALSE. Any ideas what might be wrong? I've included my Connection.hal file below.
# Keep your plasmac i/o connections here to prevent them from
# being overwritten by updates or pncconf/stepconf changes
# Other customisations may be placed here as well
# This file is built by the configurator in your configuration directory
#***** DEBOUNCE FOR THE INPUTS *****
loadrt dbounce names=db_breakaway,db_float,db_ohmic,db_arc-ok
addf db_float     servo-thread
addf db_ohmic     servo-thread
addf db_breakaway servo-thread
addf db_arc-ok    servo-thread
# for the float and ohmic inputs
# each increment in delay is a 0.001mm (0.00004") increase in any probed height result
setp db_float.delay     5
setp db_ohmic.delay     5
setp db_breakaway.delay 5
setp db_arc-ok.delay    5
#***** ARC VOLTAGE LOWPASS FILTER *****
# set the cutoff frequency if required
setp plasmac.lowpass-frequency 0
#***** THE JOINT ASSOCIATED WITH THE Z AXIS *****
net plasmac:axis-position joint.3.pos-fb => plasmac.axis-z-position
setp  hm2_7i96.0.encoder.00.scale -1
setp  hm2_7i96.0.encoder.00.filter 1
setp  hm2_7i96.0.encoder.00.counter-mode 1
#***** PLASMA CONNECTIONS *****
net plasmac:arc-voltage-in hm2_7i96.0.encoder.00.velocity => plasmac.arc-voltage-in
net plasmac:arc-ok-in hm2_7i96.0.gpio.010.in => db_arc-ok.in
net plasmac:float-switch hm2_7i96.0.gpio.001.in => db_float.in
# net plasmac:breakaway {YOUR BREAKAWAY PIN} => db_breakaway.in
# net plasmac:ohmic-probe {YOUR OHMIC PROBE PIN} => db_ohmic.in
# net plasmac:ohmic-enable plasmac.ohmic-enable  => {YOUR OHMIC ENABLE PIN}
#***** MULTIPLE TOOL ENABLE *****
# set to 1 to enable a scribe or spotting
setp plasmac.multi-tool 0
#***** SCRIBE CONNECTIONS *****
# net plasmac:scribe-arm plasmac.scribe-arm => ***YOUR_SCRIBE_ARMING_OUTPUT***
# net plasmac:scribe-on  plasmac.scribe-on  => ***YOUR_SCRIBE_ON_OUTPUT***
13 Jan 2021 21:40 #195282 by phillc54
Do you have the torch enabled in the GUI.
13 Jan 2021 22:44 #195284 by Nick7251
Oh my gosh. That was it. Man, I am such a nube. Sorry for the incredibly dumb question. Now that the torch is firing I was doing some testing. At the end of a cycle my torch height goes all the way to the top, then drops all the way back down to the bottom. Kind of weird. Anyways, I'll try to figure that out. I'm sure I'll be posting the formal question about it later. :) Thanks again.
Time to create page: 0.322 seconds
