PlasmaC Will Not Activate Torch Pin on My 7i96
- phillc54
- Thank you received: 2100
13 Jan 2021 22:48 #195285
by phillc54
Replied by phillc54 on topic PlasmaC Will Not Activate Torch Pin on My 7i96
No worries, that has caught a few.
The torch should end up where it originally started form. Normally you would set you home position around 5mm or so from the top. If you jog down for any reason then you should jog back up before doing anything else.
- pkasy
- Thank you received: 5
02 Sep 2021 21:17 - 02 Sep 2021 21:41 #219478
by pkasy
Replied by pkasy on topic PlasmaC Will Not Activate Torch Pin on My 7i96
Hello.
My plasma does not start at the command of m3.
M3 $0 S1 or M3 S1
M3 $0 S1 will probe, go to pierce height, and stoped without error messages and waits for something.
The ENABLE button is lit green.
The plasma starts up by pressing the "PULSE" button. According to the program, no.
More precisely, it started up once, yesterday, and cut a sheet of metal in half. Since then, he does not want to start even on old files. Only on the button in the GUI (Axis).
LINUXCNC - 2.8.2-11-g6a3d0a434
PlasmaC v0.188
plasmac.torch-enable is ON
Fresh config.
# Keep your plasmac i/o connections here to prevent them from
# being overwritten by updates or pncconf/stepconf changes
# Other customisations may be placed here as well
# This file is built by the configurator in your configuration directory
#***** DEBOUNCE FOR THE INPUTS *****
loadrt dbounce names=db_breakaway,db_float,db_ohmic,db_arc-ok
addf db_float servo-thread
addf db_ohmic servo-thread
addf db_breakaway servo-thread
addf db_arc-ok servo-thread
# for the float and ohmic inputs
# each increment in delay is a 0.001mm (0.00004") increase in any probed height result
setp db_float.delay 5
setp db_ohmic.delay 5
setp db_breakaway.delay 5
setp db_arc-ok.delay 5
#***** ARC VOLTAGE LOWPASS FILTER *****
# set the cutoff frequency if required
setp plasmac.lowpass-frequency 0
#***** THE JOINT ASSOCIATED WITH THE Z AXIS *****
net plasmac:axis-position joint.3.pos-fb => plasmac.axis-z-position
#***** PLASMA CONNECTIONS *****
net plasmac:arc-voltage-in hm2_5i25.0.encoder.05.velocity => plasmac.arc-voltage-in
net plasmac:arc-ok-in hm2_5i25.0.7i77.0.0.input-15 => db_arc-ok.in
# net plasmac:float-switch {YOUR FLOAT SWITCH PIN} => db_float.in
# net plasmac:breakaway {YOUR BREAKAWAY PIN} => db_breakaway.in
net plasmac:ohmic-probe hm2_5i25.0.7i77.0.0.input-14 => db_ohmic.in
net plasmac:ohmic-enable plasmac.ohmic-enable => hm2_5i25.0.7i77.0.0.output-09
net plasmac:torch-on => hm2_5i25.0.7i77.0.0.output-08
#***** MULTIPLE TOOL ENABLE *****
# set to 1 to enable a scribe or spotting
setp plasmac.multi-tool 0
#***** SCRIBE CONNECTIONS *****
# net plasmac:scribe-arm plasmac.scribe-arm => ***YOUR_SCRIBE_ARMING_OUTPUT***
# net plasmac:scribe-on plasmac.scribe-on => ***YOUR_SCRIBE_ON_OUTPUT***
M3 $0 S1 or M3 S1
PlasmaC v0.188
Fresh config.
Warning: Spoiler!
Last edit: 02 Sep 2021 21:41 by pkasy. Reason: format
- Thank you received: 5337
02 Sep 2021 21:41 #219481
Replied by PCW on topic PlasmaC Will Not Activate Torch Pin on My 7i96
if hm2_5i25.0.7i77.0.0.output-08 is true (check with halmeter)
and the 7I77 output 08 is not high , this indicates a hardware
issue.
issue.
- pkasy
02 Sep 2021 21:53 #219484
by pkasy
if I press "PULSE" button hm2_5i25.0.7i77.0.0.output-08 is true and plasma starts.
if I run "M3 S1" hm2_5i25.0.7i77.0.0.output-08 is false and plasma wait for something after probing.
02 Sep 2021 22:08 #219485
I guess you need a PlasmaC expert to tell you what it is waiting for...
- phillc54
02 Sep 2021 22:20 #219486
by phillc54
Can you make a backup from the config panel and post it here.
- pkasy
02 Sep 2021 22:24 - 02 Sep 2021 22:32 #219487
by pkasy
Here it is:
Last edit: 02 Sep 2021 22:32 by pkasy. Reason: wrong file
- phillc54
02 Sep 2021 22:32 #219488
by phillc54
Nothing there.
- pkasy
02 Sep 2021 23:18 #219489
by pkasy
Sorry?
- phillc54
03 Sep 2021 01:07 - 03 Sep 2021 01:08 #219491
by phillc54
The reason for your issue is that the Probe Speed is too slow. What is happening is that it probes down fast, finds the material, moves up a little bit then probes down slow to find the material again. Because the value is too low for the resolution it just stops. 60 is the minimum I could run on your config. If you need to probe any slower than 60 then you could add this line to the connections.hal file:
A couple of other issues I see are that the axes and joint maximum velocities are not correct. You need to have the axis max_vel double the value of the joint max_vel. The joint max_vel should be the actual maximum velocity that you require.
setp plasmac.resolution 10A couple of other issues I see are that the axes and joint maximum velocities are not correct. You need to have the axis max_vel double the value of the joint max_vel. The joint max_vel should be the actual maximum velocity that you require.
Last edit: 03 Sep 2021 01:08 by phillc54.
Time to create page: 0.322 seconds
