Manually cut off with PlasmaC
06 Nov 2019 10:06 #149681 by danilom
Manually cut off with PlasmaC was created by danilom
It might be too obvious and I can not spot it but is there a way to manually start the torch and cut off a piece of sheet ? Except pulse torch button I dont see anything else, issuing M3 S1 or M3 $0 S1 in MDI does nothing.
06 Nov 2019 10:46 #149685 by rodw
Replied by rodw on topic Manually cut off with PlasmaC
I have a Gcode script that does this but I sometimes need to edit it to change the length to cut. I use Gmocappy with Plasmac and I've been meaning to create a Gmocappy macro that allows to enter the distance to cut.
06 Nov 2019 11:29 #149694 by tommylight
Replied by tommylight on topic Manually cut off with PlasmaC
Just checked it, it does not do anything with F9 in Axis !
Damn, that is a must have feature as i know all my clients use that to cut off left over plates.
The thc_toma does that homed or unhomed, press F9 and it will probe, fire the torch, wait for ARCOK signal, move with arrow keys !
06 Nov 2019 11:53 #149698 by rodw
I think it would be easy in Plasmac to program one of its buttons when we perfect the void crossing algorithm. Then you would not need to worry about turning off the torch at the end of the cut.
06 Nov 2019 17:12 #149736 by danilom
Replied by danilom on topic Manually cut off with PlasmaC
For me right now even the most basic just fire the torch anywhere and allow me to jog will do :)
06 Nov 2019 20:04 - 06 Nov 2019 20:05 #149747 by rodw
Well I'm no Gcode wizard so I might have this a bit wrong but assuming a metric machine and a 1200mm wide sheet, you could try configuring a Plasmac button in your ini file something like this:
BUTTON_n_NAME = Sever
BUTTON_n_CODE = G91 M3 G1 X1200 F#<_hal[plasmac.cut-feed-rate]>  M5
(substituting the _n_ for the button number you want to use)
Just select the material, position the torch on the edge of the sheet wherever you want to sever and press the button. You may need to move the F command before the M3
Last edit: 06 Nov 2019 20:05 by rodw.
06 Nov 2019 21:55 - 06 Nov 2019 21:57 #149761 by phillc54
Replied by phillc54 on topic Manually cut off with PlasmaC
I didn't realise that a feature like this was required, I will look into it.
What turns the torch off?
Last edit: 06 Nov 2019 21:57 by phillc54.
06 Nov 2019 22:23 #149764 by tommylight
F9 again or esc.
06 Nov 2019 22:25 #149765 by phillc54
Thanks Tom, do you know it that works for Gmoccapy as well or is the Toma config for Axis only.
06 Nov 2019 22:47 #149769 by tommylight
Grotius made the mod for gmoccapy, last i tested it still had some issues to solve but i do not think he finished it, at least i never got to test the working version.
I did it for Axis only as that is still the only GUI i use.
