Manually cut off with PlasmaC
- Thank you received: 4150
08 Nov 2019 01:52 #149896
Replied by rodw on topic Manually cut off with PlasmaC
Phill, looks great. Time for me to do an upgrade I see. From the fields on the screen, does that imply that you can do a diagonal cut? If not, it would be better to have one length field and select x or y direction.
- phillc54
- Thank you received: 2100
08 Nov 2019 01:55 - 08 Nov 2019 01:57 #149897
by phillc54
Replied by phillc54 on topic Manually cut off with PlasmaC
Yes, say you enter 300 for x and 100 for y then the cut will end 300,100 from the start position.
Edit: I probably should have put that in the docs...
Last edit: 08 Nov 2019 01:57 by phillc54.
08 Nov 2019 03:19 #149899
Phill, the cut terminates with an error about 220mm into the cut "Its not possible to change to auto mode at the moment"
Regardless of X or Y direction
- phillc54
08 Nov 2019 03:51 #149903
by phillc54
Temporary fix pushed.
It will stay in MDI mode after the cut.
08 Nov 2019 04:21 #149904
Confirmed working. Very nice. You can even save the settings.
Time to create page: 0.092 seconds
