Manually cut off with PlasmaC
- Thank you received: 7464
06 Nov 2019 23:01 #149771
Replied by tommylight on topic Manually cut off with PlasmaC
Found it, strangely on the same thread !
forum.linuxcnc.org/plasma-laser/34978-th...with-how-to?start=10
- Thank you received: 4140
06 Nov 2019 23:38 #149773
Replied by rodw on topic Manually cut off with PlasmaC
Phill, If you added a run setting for sever width (and maybe the axis for severing direction -eg. x or y) and a button script that simply ran that distance from the current torch position using the current material settings, that would be very quick and efficient.
- phillc54
- Thank you received: 2100
06 Nov 2019 23:46 #149774
by phillc54
Replied by phillc54 on topic Manually cut off with PlasmaC
I am surprised that this question hasn't come up before (or maybe it did and I forgot).
I am not quite sure what to do here, doing it your way would mean that the machine needs to be homed and Tom wants to be able to operate it even if not homed.
I think I'll have a play and see what I can come up with...
06 Nov 2019 23:48 #149775
I would still like to have it the old fashioned way.
The buttons thing complicates things, a lot !
- phillc54
07 Nov 2019 00:03 #149779
by phillc54
First issue:
It will need to be homed for this to be effective as you can't jog synchronised joints in 2.8+ and I think most plasma machines will have synchronised joints.
07 Nov 2019 00:07 #149780
Exactly what my half finished post said. After 2.7, homing is required on a gantry machine
First issue:
- danilom
- Thank you received: 5
07 Nov 2019 16:00 #149853
by danilom
Replied by danilom on topic Manually cut off with PlasmaC
While you are all here I have one more question.
What determines the position of Z axis on the end of cut, sometimes it goes in upper most position but sometimes it goes back down to the material to some height
07 Nov 2019 16:09 #149855
Yup, forgot that ! Sorry.First issue:
- phillc54
07 Nov 2019 22:37 #149892
by phillc54
The best way to run PlasmaC is to have your Z home position at the highest point you want to return to. Once you have homed Z don't do any Z jogging, let PlasmaC handle all Z motion. Hopefully this link linuxcnc.org/docs/devel/html/plasma/plas....html#_using_plasmac will help a bit. It probably needs to be written a bit better...While you are all here I have one more question.
- phillc54
08 Nov 2019 01:48 #149895
by phillc54
I have pushed an update with this feature named Single Cut for want of a better name.
It has the way Tom wanted and also a way similar to what Rod suggested.
pic from user guide
extract from the user guide
It has also got me thinking that it may not be too difficult to add some simple conversational stuff, say rectangles, circles, etc.
Maybe on a new tab called Conversational.
Is this worthwhile?
pic from user guide
Is this worthwhile?
The following user(s) said Thank You: tommylight, Clive S
Time to create page: 0.139 seconds
