Plasmac Post Processors
- Thank you received: 7478
11 Sep 2025 17:58 #334836
Replied by tommylight on topic Plasmac Post Processors
There are no
N75 M3 $0 S1
in the gcode after the first piece, and no M5 at the end of the cut except for the first cut.
Those must be added by the post processor.
N75 M3 $0 S1
- mal136
13 Sep 2025 06:17 #334914
by mal136
Replied by mal136 on topic Plasmac Post Processors
IInteresting—I used the Fusion360 post processor from the first page of this thread (forum.linuxcnc.org/plasmac/38438-plasmac...t-processors?start=0). After rereading the PDF, it doesn’t explicitly say so, but I think I need to create separate 2D profiles for each feature I’m cutting. Since the post processor doesn’t generate Z movements, would that mean making individual profiles for all 12+ holes plus the part outline? and i assume plasmaC will control Z when it goes to probe for each cut? I also tried Inkscape (which I like), but it skips certain splines and rounded corners in my parts. Redesigning everything just to fit Inkscape’s gcode output would be counterproductive.
Thank you so much Tommylight for your reply, i greatly appreciate your help!
13 Sep 2025 16:04 - 13 Sep 2025 16:05 #334933
Sorry i can not help with Fusion, i use strictly Inkscape for all plasma machines, just use "prepare for plasma" and then export with the tool chosen as plasma.
Last edit: 13 Sep 2025 16:05 by tommylight.
- twatchorn
31 Aug 2026 04:32 #349151
by twatchorn
Replied by twatchorn on topic Plasmac Post Processors
I am using Fuson 360 and QtPlasmaC.
I am having the start radius - end radius errors that I see others have but don't know or understand the remedy. As far as I know I am using the second PP on the list below as when I go to import it, is says it already exists and do I want to cancel or replace.
Clicking of the first link to QtPlacmac PP does not take we to a file for downloading. Is this PP somewhere and the link needs correcting?
Can someone help with a PP. or with instructions for a dummy on how to not get the errors
Kind regards Trevor
Kind regards Trevor
This thread is for user donated post processors for CAM software that has no native post processer for QtPlasmaC/PlasmaC.
I will make this sticky and unlocked and just keep current versions here.
If there are posted comments or corrections I will delete them after they have been actioned.
Current PP's:
- Fusion360 - QtPlasmaC
- Fusion360 - PlasmaC (AXIS & GMOCCAPY)
- ProNest 2019
- SOLIDWORKS (CAMWorks)
- Inkscape
- PeddiNest
There are no third party PP's here for SheetCam, use the PlasmaC PP included with SheetCam for both QtPlasmaC and Plasmac.
PP creators need to be aware of the following:
- LinuxCNC does not allows analog/digital input or output while cutter compensation (G41) is active.
- QtPlasmaC disables G92 offsets.
All work product by the author is provided “AS IS”. The Author makes no other warranties, express or implied, and hereby disclaims all implied warranties, including any warranty of merchantability and warranty of fitness for a particular purpose.
Time to create page: 0.295 seconds
