Plasmac Post Processors
2 years 8 months ago - 2 years 8 months ago #292910 by phillc54
Replied by phillc54 on topic Plasmac Post Processors
The attached  Custom G-code Filter  should render the G-code suitable for QtPlasmaC.
Copy custom_filter.py to the configuration directory for the plasma table.
Some examples of typical PeddiNest G-code files are attached.
You do need to be aware that all the motion in these files is incremental.
File Name: custom_fil...02-08.py
File Size:768 B
Last edit: 2 years 8 months ago by phillc54.
2 years 8 months ago - 2 years 8 months ago #293158 by grijalvap
Replied by grijalvap on topic Plasmac Post Processors
Hi  Phill
Question just to be sure I understand correctly:
in the custom_pre_parse(data)  funtion "data" is a single row or a array of rows.
then if it is a single row (as i think) the return data is the statement that will substitute the actual row?
Edit..
The code you sent me is working now I added pre and post amble.
thanks
Last edit: 2 years 8 months ago by grijalvap.
2 years 8 months ago #293185 by phillc54
Correct:
  • data is a single line of G-code from the loading file.
  • the return may be None to delete the line, a single line of G-code, or multiple lines of G-code separated by a newline.
Great, glad it works. You may need to ensure that it does not affect code written by another PP.
2 years 7 months ago #294914 by anthonylangevin
hi i got a problem with your post . i got no M3 commaand for starting the plasma do you have a clue what i am doing wrong
2 years 7 months ago #294956 by phillc54
What post are you referring to and what exactly are you currently doing?
Maybe attach your g-code file here as well.
2 years 1 month ago #310231 by SteveatSteelCut
Curious to know if the script for the post processor in qtplasmac worked for anyone?
Currently I am using a different post processor and it runs through a filter on qtplasmac which works ok. But some files it has issues with and I can't use the option to start at a certain line.
So I thought I would try and run this cff to see if it was a better option, using 2015 hypertherm nestmaster.
I used the cff for pronest on this thread. Screenshot and gcode attached.
Time to create page: 0.401 seconds
