- Thank you received: 907
phillc54 wrote:
snowgoer540 wrote: haha, I can relate. I was just getting ready to sit down and see if I could copy paste, snip something together for an idea, see if I come up with anything.
Should I hold off on that?
No, I am open to suggestions.
Thanks for that and a bit of an explanation would be nice.snowgoer540 wrote: Also, I should note, some of the colors aren’t what I’d go with in the final (background, gcode area). But you can only do so much with snippet and PowerPoint in the time allotted lol
Personally I am not a fan of too much colour, for me the less the better.
I think we need to start with what are the required controls on the "main" panel.
I see you don't have jog keys, does everyone have a pendant?
You probably should allow for 4 axes in case a user has a rotary axis for pipe cutting.
Is DTG required, personally I have never used it as it is only for the current segment, if it was to the end of the cut it would make some sense.
Cool.I will make a version 2 tomorrow sometime, and give a bit of an explanation.
That is where it should be, the main screen is the most important (well it is to me anyhow).I agree, my focus was on the main tab, the rest can follow behind that.
