GUI for PlasmaC - QtPlasmac
- Clive S
- Thank you received: 486
I'm excited to hear what you think.
I really like the clean lines which for my eyes give a good contrast
- snowgoer540
- Thank you received: 907
Attached is V2.0 with some explanation slides.
Cool.I will make a version 2 tomorrow sometime, and give a bit of an explanation.
That is where it should be, the main screen is the most important (well it is to me anyhow).I agree, my focus was on the main tab, the rest can follow behind that.
Let me know what you think!
-Greg
- Thank you received: 4155
Definitely need a home all button. Thats all I use and is how 2.8 and master are designed to be used. Gmoccappy is annoying here though becasue there are 2 key strokes at top right to turn machine on and then 2 key strokes at bottom left to home all. Keep them close together. It annoys me every time I turn the machine on (which is the only time I home it)
Need to display the voltage set point and buttons to adjust it up and down. I found on material I had not cut before this allowed quick tuning of the set point (which I later used to modify the cut height eg adjustment on the fly of 3 volts meant I changed cut height by 0.3mm)
Don't loose Phill's laser reference buttons. Thats all I use to pick 0,0.
The concept of testing ohmic sensing to trigger the enable relay is going to be obsolete (it is for me now) with hyper sensing with a THCAD-5.
Need a decent size button to accept MDI input. Gmocappy is woeful in this area with a tiny tick which is too small to use on a touch screen and thats what its designed for. I often select an earlier entered line and can't enter it without a mouse.
I don't understand why we are wasting screen real estate for a spindle and associated tools on a plasma machine. If you must retain it, put it on a secondary tab that is not displayed by default.
I think the onscreen estop/machine on probably needs to be retained to keep Linuxcnc happy. If you do hit estop, you need to hit a screen button to confirm its been cleared to continue.
I'm sure I missed a lot!
- snowgoer540
Are you commenting on my concept specifically, or the Plasmac GUI in general? Just ask because I didnt have any spindle stuff on my concept.
- Clive S
- snowgoer540
I personally prefer the colour scheme in V1. to V2 as I find it easier to read.
I'm sorry about that, I didnt realize i had a screen shot on top of the actual slide for the first page. It killed some of the quality when it output.
I deleted the .pdf from my post, and uploaded a new version. I also added the V1 screen shot to the beginning to make the comparison easy.
Please take a look again and see if you still find it hard to read, I suspect some of that was due to it being a screen shot, and not the real deal.
EDIT: Attached here as well for your convenience
On both. I did not see the laser reference on yours.
- islander261
- Thank you received: 216
1. How is the machine taken out of or E-stopped?
2. How are the axis/machine homed?
3. How are the work piece offsets entered?
4. What about the reverse run? This is a very use full feature for cutting error recovery!
High contrast and brightness rule for old guys.
- snowgoer540
I am way late here so I may have missed some points.
Hey John,
I hit most of that in the explanatory slides. But I'll touch here quick.
1. click the machine button, if it's not physically E-Stopped, it will allow it to power on. If it's physically e-stopped you'd get an error message telling you such. E-Stops should be physical hardware for maximum safety. I never understood the need for the software estop.
2. Click Reference. Right now I have them individually, but I could add a home all as well. I was waiting to hear Phil's comments.
3. Either click Zero Axis, or you could type manually in the DRO window is the current plan.
4. Good question. I dont have reverse run as I am on 2.8, but I Am open to suggestion as to what might be necessary there!
-Greg
- Clive S
Yes that is much better and is good but my preference is V1 because for me the yellow around the boxes stands out.
I personally don't like touch screens.
I am no commenting on the content as I think that is for the pro's that do it for a living .
I do hope this will get finished
