GUI for PlasmaC - QtPlasmac
- phillc54
- Thank you received: 2100
Yes I do agree that EStop should be an indicator only but many here think that an EStop button is required on the GUI.
Sorry, I guess I was confused. I had left the e-stop button off because I thought you agreed earlier in the thread that we only needed an indicator light, and that software e-stops were a bad thing to rely on?You are going to need a EStop as most folk here expect to see one.
My intention is that eventually this will be the only GUI I support on PlasmaC as is is difficult to keep supporting both AXIS and Gmoccapy plus we do eventually need to move to a more modern GUI toolkit. This won't be able to happen if guys won't use it.
- snowgoer540
- Thank you received: 907
I’ll use it
Should I keep making revisions?
- islander261
- Thank you received: 216
Phill's work on GUI modifications for both Gmoccapy and Axis took place over a number of months with people actually using the GUIs for production cutting and providing feedback. You need to think of the main GUI page as your day long work place and how many times do you want to go to sub menus for part or material changes or to fix cutting errors (tip ups, probing errors, consumable changes). I can tell you and I think '03 will as well it isn't uncommon to have multi hour long cutting sessions on one sheet and it is really nice to be able to monitor the actual cutting conditions from the main GUI to track failing consumables or other problems. I actually have routine cutting that is over 1500 pierces one single sheet with some actually using up a new set of consumables (over 3,000 pierces) on a single sheet. E- stop and machine on and off from the main screen are handy when you are spending a lot of time at the console.
- phillc54
HAHa, I read this a couple of times and read it as "look at this" and totally confused myself when all the time it was "look at this" .Look at the controls and indicators on the Gmoccapy PlasmaC GUI main screen and try to incorporate their functionality into your display, they are what is needed for cutting.
I think I need a break...
- Thank you received: 4155
But I think you really need to look at this with the plasmac side panel enabled....
These days thats all been delegated to PhillC because Plasmac rules
- Clive S
- Thank you received: 486
Just a thought
As above this is going to be a very nice gui.
- snowgoer540
Is it really necessary to have 7 digits in a DRO for a plasma as if that was reduced it would give more real estate.
Just a thought
Haha true, also I’m disappointed no one caught my Easter eggs lmao
- alexandrub
- Thank you received: 5
- snowgoer540
So should I continue to tweak the concept I had been working on, or not? I dont want to step on any toes or anything/do unnecessary work.
