GUI for PlasmaC - QtPlasmac
- phillc54
- Thank you received: 2100
Does that work OK John, I knew you used Cut Volts from the Cut Parameters but I wasn't sure if you used height override.islander261 wrote:
I use the arc voltage adjust when compensating for worn consumables, I don't use the auto voltage set feature.
If you use preset Cut Volts like John does above.tommylight wrote:
And what would be the use of height overide on an automated machine that can adjust height at any time.
- snowgoer540
- Thank you received: 907
Please see attached for Version 3. It's on page 3 of the PDF attached.
I took off Auto Volts because it seemed like no one uses it, is that ok?
Let me know how I did. I know some of the text is a little small now. We can work on that, but just the overall feel?
-Greg
- phillc54
I took off Auto Volts because it seemed like no one uses it, is that ok?I think most folk do use Auto Volts.
- snowgoer540
Let me make sure we are talking about the same thing.
Auto volts to me is the one where it takes your current height and tries to maintain that on its own, based on the voltages it's seeing.
I think the other "auto volts" is when you specify it in the cut parameters, and then it automatically tries to keep that value.
Or am I way off base?
- snowgoer540
- phillc54
There is only one Auto Volts which does as you say on line one above. It then keeps the voltage to the Cut Volts specified in the Cut Parameters.Let me make sure we are talking about the same thing.
You are going to need a EStop as most folk here expect to see one.Please see attached for Version 3. It's on page 3 of the PDF attached.
I would be tempted to put Estop, Machine (On/Off) & Exit above the loaded file name at the top left.
These buttons are normally only used once each per session and they are then quite a distance from other buttons so less likely to be inadvertently pressed.
- islander261
- Thank you received: 216
We are using autovolts to refer to the optional method PlasmaC can use to set the commanded arc voltage using a sample at the start of the cut rather than the voltage set in the material table. Many use it, I don't.
Look at the controls and indicators on the Gmoccapy PlasmaC GUI main screen and try to incorporate their functionality into your display, they are what is needed for cutting.
- Thank you received: 2181
Chris
- snowgoer540
Sorry, I guess I was confused. I had left the e-stop button off because I thought you agreed earlier in the thread that we only needed an indicator light, and that software e-stops were a bad thing to rely on?
But at any rate, it's easy to add. Top right probably makes sense!
- snowgoer540
Once you have one basic design it's also easy to have a second layout tweaked for a specific process.
Chris
That is a very solid point. I think the basic design might be there?
I think some of this gets confused by others because none of the other tabs are defined yet.
I just worry if there is a resistance to some of it because change is scary/difficult sometimes. Clearly not all will agree on every change/layout. But I think we can get a really nice one, and then those people can edit from there?
I dont want to make a different colored version of Gmocappy, or axis. Those were GUIs intended for milling machines. I want to make something that makes sense for this plasma controller.
I wonder where the point is that we move from concept to actual coding/design of the GUI. I'm more than happy to keep churning out different versions out of Powerpoint, but I want to make sure I'm not wasting time either.
