GUI for PlasmaC - QtPlasmac
5 years 7 months ago #201143 by phillc54
crowloy wrote: So i've been playing with qtplasmac. I really hate the yellow :)
Change it then:
linuxcnc.org/docs/devel/html/plasma/qtpl...ml#qt_parameters-tab
So I've been doing some editing. Read on the qtdragon forum, about F12 and the style sheet editor. So I've been playing with it.
One issue I think I found is that you can;t load a bitmap to the main screen like qtdragon does
It is limited as to what can be customised:
linuxcnc.org/docs/devel/html/plasma/qtpl...mizing_qtplasmac_gui
5 years 7 months ago - 5 years 7 months ago #201519 by phillc54
QtPlasmaC should be now fully functional and able to be used on plasma tables provided that you have master branch.
There are two methods for migrating a PlasmaC config to a QtPlasmaC config
If any Qt dependency errors are encountered after the migration, you may need to run the QtVCP installation script to resolve these issues.
For a package installation (Buildbot) enter the following command in a terminal window:
/usr/lib/python2.7/dist-packages/qtvcp/designer/install_script
For a run in place installation enter the following command in a terminal window:
~/linuxcnc-dev/lib/python/qtvcp/designer/install_script
Last edit: 5 years 7 months ago by phillc54.
The following user(s) said Thank You: tommylight, Clive S, Pro_El, robertspark, Mud, cspice, snowgoer540, pinder
