GUI for PlasmaC - QtPlasmac
5 years 8 months ago #198728 by rodw
Replied by rodw on topic GUI for PlasmaC - QtPlasmac
Mud wrote: I've been watching this thread with interest but sadly been too short on time to play. I'm currently running Linux 2.8 on Mint 19.2 and I must be 3+ months behind on PlasmaC - I've ordered a new SSD to join in without worry of scuppering myself and running out of playtime. What's the current recommendation to get up and running with minimal fuss?
What I did when I was way out of date was to build a config with pncconf with no config and cut and paste the configured data until I had a working config without plasma, Than ran the configurator.
I think I'll need to do that again with qt plasmac soon. I have it running with a 7i76e in my office but no motion hardware.
5 years 8 months ago #198734 by tommylight
The following user(s) said Thank You: Mud
5 years 8 months ago #198735 by tommylight
rodw wrote: I think I'll need to do that again with qt plasmac soon.
Shhh.... do not tell Phill, but i did make QtPlasmaC work on the big machine in about 5 minutes, then after a while tried to do that on my main PC and could not make it work for over an hour so i gave up ! I will have to copy it from there and use it everywhere and save it as if it was dinosaurs DNA ! No, not the Australian "dinosaur" that you guys keep mentioning, i still do no know what that is about or i forgot or ... :)
5 years 8 months ago #198742 by phillc54
rodw wrote: Updated 2.9 RIP this morning and I'm getting this on startup:
Qtvcp encountered an error. The following information may be useful in troubleshooting: LinuxCNC Version : 2.9.0~pre0 Traceback (most recent call last): File "/home/rod/linuxcnc-dev/share/qtvcp/screens/qtplasmac/qtplasmac_handler.py", line 1395, in <lambda> self.consChangePin.value_changed.connect(lambda v:self.consumable_change_changed(v)) File "/home/rod/linuxcnc-dev/share/qtvcp/screens/qtplasmac/qtplasmac_handler.py", line 1154, in consumable_change_changed self.w[self.ccButton].setEnabled(False) File "/home/rod/linuxcnc-dev/lib/python/qtvcp/qt_makegui.py", line 341, in __getitem__ return getattr(self, item) AttributeError: 'VCPWindow' object has no attribute ''
This is on my Chromebook. Is there another new module required?
I just pushed the fix for this.
5 years 8 months ago #198746 by rodw
phillc54 wrote:
I just pushed the fix for this.[/quote]
Thanks, I was thinking afterwards that there needs to be some error checking for this so that a user changing a button config does not break the system.
And don't forget we need a few buttons left for the user to use!
5 years 8 months ago #198749 by phillc54
rodw wrote:
phillc54 wrote: I just pushed the fix for this.
There is and this was a bug...
The eight user buttons can be any valid user button, none are set in stone...
Time to create page: 0.076 seconds
