- Thank you received: 216
rodw wrote: Updated 2.9 RIP this morning and I'm getting this on startup:
Code:Qtvcp encountered an error. The following information may be useful in troubleshooting: LinuxCNC Version : 2.9.0~pre0 Traceback (most recent call last): File "/home/rod/linuxcnc-dev/share/qtvcp/screens/qtplasmac/qtplasmac_handler.py", line 1395, in <lambda> self.consChangePin.value_changed.connect(lambda v:self.consumable_change_changed(v)) File "/home/rod/linuxcnc-dev/share/qtvcp/screens/qtplasmac/qtplasmac_handler.py", line 1154, in consumable_change_changed self.w[self.ccButton].setEnabled(False) File "/home/rod/linuxcnc-dev/lib/python/qtvcp/qt_makegui.py", line 341, in __getitem__ return getattr(self, item) AttributeError: 'VCPWindow' object has no attribute ''
This is on my Chromebook. Is there another new module required?
snowgoer540 wrote: To get past this in the meantime I just added a change consumables button. For example (formatted for dinosaurs):
Code:BUTTON_6_NAME = CHANGE\TIPS BUTTON_6_CODE = change-consumables X1 Y1 F150
I'm sure it will get tidied up then.
