GUI for PlasmaC - QtPlasmac
6 years 7 months ago #159911 by islander261
The torch pulse is useful for staring the torches post flow to clear water or debris from torch or material top.
I use the arc voltage adjust when compensating for worn consumables, I don't use the auto voltage set feature. I do like to see the actual arc voltage displayed.
6 years 7 months ago #159936 by tommylight
Same as Icelander, no autovolts and i have a big display of voltage.
And what would be the use of height overide on an automated machine that can adjust height at any time.
Frankly, i can not think of any use for it, and i still stand by the "as simple as possible" thingy. And i am complicated, a lot. :)
6 years 7 months ago #159951 by phillc54
Does that work OK John, I knew you used Cut Volts from the Cut Parameters but I wasn't sure if you used height override.
If you use preset Cut Volts like John does above.
6 years 7 months ago - 6 years 7 months ago #160095 by snowgoer540
Please see attached for Version 3. It's on page 3 of the PDF attached.
I took off Auto Volts because it seemed like no one uses it, is that ok?
Let me know how I did. I know some of the text is a little small now. We can work on that, but just the overall feel?
-Greg
Last edit: 6 years 7 months ago by snowgoer540.
6 years 7 months ago #160096 by phillc54
I think most folk do use Auto Volts.
6 years 7 months ago #160097 by snowgoer540
phillc54 wrote:
Let me make sure we are talking about the same thing.
Auto volts to me is the one where it takes your current height and tries to maintain that on its own, based on the voltages it's seeing.
I think the other "auto volts" is when you specify it in the cut parameters, and then it automatically tries to keep that value.
Or am I way off base?
Time to create page: 0.072 seconds
