THCAD selection including ohmic sensing
1 year 7 months ago #324344 by roland206
rodw and tommylight thanks for your answers. Although I have to admit I am stil confused.
I bought a cheap pilot arc plasma to play arround. It has an explicit connection between the tip and the workpiece. Ohmic sensing can't be done. Right?
Anyhow, I build a CNC Plasma and I am looking for a suitable frontend (plasma and torch) my wishlist includes:
1 plasma cutter (hopefully < $1000) with a european distributor
2 Ohmic or hypersensing (willing and able to build homemade electronics if I know what)
3 THC with a THCAD-x (best case with an avaibale THCAD-300)
Can someone propose a setup ?
1 year 7 months ago #324353 by tommylight
Stahlwerk
www.stahlwerk-schweissgeraete.de/Plasmaschneider-CUT
Good quality and cheaper than china, vertical machine torch is 40E in Germany, with 5 meter cable is 90E, bought both.
Mind the pilot arc, there are some without it so do not get those, it is easy just look for a red knob on the bottom front and usually it is written in spec info.
Time to create page: 0.263 seconds
