- Thank you received: 907
PCW wrote: Yes the 5i25 --> 7I76 config is wired the same as the 7I96 and 7I76E configs:
The encoder connector has 3 encoders with only 'A' channels so instead of
the standard 1 encoder with A,B,IDX you have 3 encoders with only 'A' pins
tommylight wrote: There is one important thing that is being left out from all this chat about ohmic/hyper sensing:
Most of the "normal" plasma sources use the shield in the torch to strike the arc between it and the electrode, that means having, in some cases, over 20000V AC on that pin/shield.
That poses a risk for everything attached to it, even relays will not stop that from arcing over.
It would be nice to mention from time to time that this type of sensing is for double shielded torches, that usually have no connection to the outside shield and a wire needs to be added and attached to that shield.
I still did not get the 5 THCAD i ordered through a "friend of a friend", for sure i will sacrifice one to see if i can find a way to use them on such devices as almost all plasma sources i use here are of this type, namely the Trafimet A141 or A161 torches with the shield wired to the high voltage arc start.
Uthayne wrote: So I'm getting ready to install a THCAD-5 for ohmic sensing in my build and I was reviewing the wiring schematic in the primer doc. I have a Hypertherm Powermax 45XP with the ohmic sensing retaining cap so I'll be wiring up to that. My question is with the THCAD-5 IN- connected to the torch shield, is there a possibility of raw arc voltage going back to the electronics cabinet where the THCAD-5 will be installed due to slag shorting out the shield or some other fault? I realize it isn't an issue for the THCAD itself and the circuit is isolated, but I'm running a 3 conductor wire (small, maybe 22ga?) to the torch from the cabinet. Two wires are used for the float switch and the third is for the ohmic wire. Just wondering if there's potential for any issues or if I should run it's own separate wire just for the ohmic cap, separate from the other two.
