THCAD selection including ohmic sensing
6 years 7 months ago #160245 by tommylight
Damn! Please do not touch those 2 pins while the plasma is on!
I really hope they bothered to put some resistors inside of that thing.
In that case a THCAD300 should do just fine and save you a lot of work.
Please also use proper isolation for that connector and make sure those two wires are not pinched or crimped somewhere.
6 years 7 months ago #160247 by PCW
calvin.d wrote: The back of the machine shows 1:1 as the ratio so I believe I need the 300v option, picture added
for the ohmic sensing side of the question, it seems like going with 5v and just adding a small 5v power supply to the system is the easiest option. Compared to getting a 10v supply or dividing down the 24v power the system to less then 10v
Thank You
C
Actually you want a higher sensing voltage, 24V or even 48V is suggested
Note that this needs to be an independent floating supply (no connections to anything else in the system)
6 years 7 months ago #160269 by rodw
Can you measure the resistance from the electrodes at the front of the machine and those pins on the back of your machine?
I would expect that there is around 100k ohm resistance if its like any other machine that has raw voltage output so you don't kill yourself.
I think you should use a THCAD-10 so that you can account for this resistance. eg. follow the example in the THCAD-10 manual and then deduct the resistance (200 k Ohms?) from the calculated values.
Also using a THCAD-10/5 for ohmic sensing will require a component I have written but its not yet published.
6 years 7 months ago #160283 by tommylight
rodw wrote: Also using a THCAD-10/5 for ohmic sensing will require a component I have written but its not yet published.
Oh, you've been holding on us ! :)
6 years 7 months ago #160317 by bevins
What? What does the component do? I bought two of the thcad-10 to use for this.
Are you going to release the component? Did I ask what the component does?
6 years 7 months ago #160318 by tommylight
bevins wrote: Did I ask what the component does?
Yes you did.
Time to create page: 0.357 seconds
