- Thank you received: 4153
islander261 wrote: Well it may not be quite that simple depending on ones actual hardware. In most case the arc voltage sensing (THC) is sensed between the torch electrode and the work piece. For ohmic sensing usually you want to measure the potential between the torch shield and the work piece.
PCW wrote: If you use a THCAD and an isolated power supply for Ohmic sensing, there _is_ no connection between the shield sense and the plasma voltage except the common work sense point. Adding a relay makes no sense
