PlasmaC Fiber laser 1Kw head height control + auto focuas
6 years 1 month ago #183355 by phillc54
No, the only height testing is the probe test.
6 years 1 month ago #183357 by taloot
taloot wrote: i rework the capacitance sensing
is there any command allow me to test the head follower aka thc
without running programe
by mistake i burn one of the fpga pin.. for encoder A,, but B still ok.. can i use B line instead of A
6 years 1 month ago - 6 years 1 month ago #183358 by taloot
aslo i want 7i96 firmware with 3 pwmgen or if possable i want to swap pins between enc A and ENc B
Last edit: 6 years 1 month ago by taloot.
6 years 1 month ago #183378 by PCW
I could replace all encoder pins with "A" pins of different encoders
as is done with the 7I96 plasma config
The following user(s) said Thank You: taloot
6 years 1 month ago #183525 by PCW
File Name: lotsofencs.zip
File Size:109.49 KB
7I92 config for 5ABOB with extra PWMGens with all encoder pins
being "A" pins (so 6 encoders available for frequency measurement)
The following user(s) said Thank You: tommylight, taloot
6 years 1 month ago #183566 by tommylight
PCW wrote: 7I92 config for 5ABOB with extra PWMGens with all encoder pins
I was afraid to ask ! :)
Thank you.
Time to create page: 0.248 seconds
