taloot.
Thank you for the video.
I mentioned the LFS-AP01 capacitive sensor, you mentioned the BCL-Amp was better.
Can you explain how this could be ?
I went back and tested a BCL-Amp and it didn't register any reading of signals out.
The LFS-AP01 I am testing registers 0.03v to 0.04v sensitivity, do I need a better read value than this ?
When the LFS-AP01 is put through the DT-115 it reads 0.003v sensitivity.
Are you using G and M codes for your operation ?
It would good to see the header and footer notes in the file.
Cheers.
problem with response time and accuracy
