Thanks taloot.
The information you say is accurate to the information to what I have sourced.
For one instance, I should not have a need for 50M/min on the Z axis.
I have settled on 21.9 M/min on the X and Y axis, due the maximum 110 Htz available from the controller.
The challenging part is no problem regarding building the machine.
I am still working with the LFS-AP01 sense, I have now replaced the relays of the DT-115 with Photo Mos relays.
This is now working to 0.002v between the high / low signals for the Fibre Laser sense head height.
The setting of the actual read voltage is set around to 0.0004v, but the read voltage will be a digit higher when running.
I have ordered volt metre to read the extra digit.
A video showing the reaction is below, not at 20M/min, but it works.
youtube.com/shorts/hTQ89CG5kpU
Cheers, Lilow
