- Thank you received: 907
Hypersensing questions
- snowgoer540
6 years 6 months ago #164361
by snowgoer540
Replied by snowgoer540 on topic Hypersensing questions
I also confirmed that there is 24 volts when the torch is against a work piece on the table. And, I confirmed that it doesnt work by doing a M3 $0 S1 just to make sure I wasnt going insane. Still no ohmic sense.
- Thank you received: 4153
6 years 6 months ago #164364
Replied by rodw on topic Hypersensing questions
What is happening to plasmac:ohmic-enable?
It should go true when you are probing and it needs to be connected to the ohmic component. via the debounce pin that we unlink.
6 years 6 months ago #164365
Sorry this pin
plasmac.ohmic-enable
- Uthayne
- Thank you received: 49
6 years 6 months ago #164366
by Uthayne
Replied by Uthayne on topic Hypersensing questions
I had to edit the line to add plasmac.ohmic-enable pin
net plasmac:ohmic-enable plasmac.ohmic-enable => ohmicsense.is-probing
Without it, the ohmicsense.is-probing never went true while probing
6 years 6 months ago - 6 years 6 months ago #164367
Sorry, In my config, that signal passes through a debounce component so that is what I unlinked. Maybe yours does not debounce it.
So you should be good to go after checking the thresholds.
Last edit: 6 years 6 months ago by rodw.
- snowgoer540
6 years 6 months ago #164368
by snowgoer540
Neither of them ever changed that I noticed.
rodw wrote: What is happening to plasmac:ohmic-enable?
Time to create page: 0.886 seconds
