Hypersensing questions
- Uthayne
- Thank you received: 49
18 Apr 2020 02:05 #164386
by Uthayne
Replied by Uthayne on topic Hypersensing questions
hal show works. I usually open up hal meter and select the ohmicsense.ohmic-volts pin
- snowgoer540
- Thank you received: 907
18 Apr 2020 02:34 #164388
by snowgoer540
Ok thanks. So it’s causing you a bunch of false trips?
Replied by snowgoer540 on topic Hypersensing questions
- Uthayne
18 Apr 2020 02:39 #164389
by Uthayne
Correct. Then I either have to wait a while for it to dry out, or disassemble it completely and run the air through it. It's still not guaranteed to get it to drop the voltage. I'm not really sure how to prevent it though. If there was less noise/fluctuation on the line, it may be more controllable via the set points
- snowgoer540
18 Apr 2020 02:50 #164390
by snowgoer540
What brand cutter are you using?
Do you use the encoder filter?
- Uthayne
18 Apr 2020 02:52 #164391
by Uthayne
Hypertherm Powermax 45xp with machine torch
Yes the encoder filter is enabled
- Thank you received: 4149
18 Apr 2020 04:05 - 18 Apr 2020 04:06 #164393
Replied by rodw on topic Hypersensing questions
Ah, I figured it out. I already had defined plasmac:ohmic-enable in my connections.hal with:Sorry about that guys.
This is a hangover from my earlier relay based config.
I'm wondering now if the relay system would work with a short in the torch from water. Certainly the relays I used had on and off points well below the off threshold.
I wonder if its worth trying a 48 volt power supply and changing the THCAD scaling? Would that increase the on/off threshold. Maybe PCW could chime in here with his thoughts.
net plasmac:ohmic-enable plasmac.ohmic-enable => hm2_7i76e.0.7i76.0.0.output-11This is a hangover from my earlier relay based config.
Last edit: 18 Apr 2020 04:06 by rodw.
- phillc54
- Thank you received: 2100
18 Apr 2020 04:36 #164396
by phillc54
Replied by phillc54 on topic Hypersensing questions
@Rod
Do you want to change the bottom of the Primer to read something like:
# --- Replace Plasmac’s Ohmic sensing signal ---
unlinkp debounce.0.2.in
net ohmic-true ohmicsense.ohmic-on => debounce.0.2.in
# --- If you have a valid plasmac:ohmic_enable connection above then add this line:
net plasmac:ohmic-enable => ohmicsense.is-probing
# --- If you do not have a valid plasmac:ohmic_enable connection above then add this line:
net plasmac:ohmic-enable plasmac.ohmic-enable => ohmicsense.is-probing hm2_7i76e.0.7i76.0.0.output-11Please Log in or Create an account to join the conversation.
18 Apr 2020 04:47 #164399
Phill,
I think I am the outlier. It probably should just be:
Not many people will have used two different methods so it really was my bad.
I posted on another thread an idea for a different algorithm which might solve the water table issue. So I'll be interest to receive feedback
# ---Connect Plasmac’s is-probing signal ---
net plasmac:ohmic-enable plasmac.ohmic-enable => ohmicsense.is-probingNot many people will have used two different methods so it really was my bad.
- phillc54
18 Apr 2020 09:29 #164432
by phillc54
I thinking that folk you don't have ohmic setup at all won't have the plasmac:ohmic-enable signal and those that have relay ohmic will.
18 Apr 2020 09:35 #164434
Yes I think they are mutually exclusive
Time to create page: 1.238 seconds
