Hypersensing questions
- Thank you received: 4152
25 Mar 2021 11:55 #203606
The Plasmac wrench in the examples..
Replied by rodw on topic Hypersensing questions
What wrench are you talking about?
- bevins
- Thank you received: 338
25 Mar 2021 12:00 - 25 Mar 2021 12:18 #203608
by bevins
Replied by bevins on topic Hypersensing questions
Do I need to have linuxcnc-dev to use halcompile?
OK, nevermind, done. Installed ohmic3 comp apparantly....
Last edit: 25 Mar 2021 12:18 by bevins.
25 Mar 2021 12:08 #203610
I think there is a linuxcnc dev package with all the dev tools if you are not compiling from source. Also if not compiled form source (RIP) I think you have to use sudo.
I have always compiled RIP.
- bevins
25 Mar 2021 12:18 - 25 Mar 2021 12:20 #203611
by bevins
I got it compiled and installed.
Just had to isntall the uspace-dev's
transnord@plasma:~/ohmic$ sudo halcompile --install ohmic3.comp
ohmic3.comp:0: Warning: File contains DOS-style or Mac-style line endings.
Compiling realtime ohmic3.c
Linking ohmic3.so
cp ohmic3.so /usr/lib/linuxcnc/modules/
Last edit: 25 Mar 2021 12:20 by bevins.
- crowloy
- Thank you received: 19
27 Mar 2021 14:16 #203807
by crowloy
Replied by crowloy on topic Hypersensing questions
Since Mesanet doesn't have any thcad-5's in stock, would a thcad-10 work as well? I'ved ordered one of these, and if I need to modify it for a -5 I'll order the parts needed. But if it works as is, it's a much simpler solution.
27 Mar 2021 19:30 - 27 Mar 2021 19:31 #203825
Just follow the formula in the mesa manual and chose a scaling resistor that gives a full scale of 24. 5 volts. From memory for the THCAD-10 145k to 147 k depending on resistor series.
Last edit: 27 Mar 2021 19:31 by rodw.
- crowloy
28 Mar 2021 13:20 - 28 Mar 2021 13:30 #203898
by crowloy
n/m
Last edit: 28 Mar 2021 13:30 by crowloy.
Time to create page: 0.123 seconds
