Hypersensing questions
22 Mar 2021 13:11 - 22 Mar 2021 13:31 #203235 by bevins
Replied by bevins on topic Hypersensing questions
Is there a preference or a link for a suitable 24v isolated power supply? I see in the docs HDR-15-24 but I cant find availability.
Last edit: 22 Mar 2021 13:31 by bevins.
  • snowgoer540
  • snowgoer540's Avatar Topic Author
  • Moderator
  • Moderator
22 Mar 2021 13:33 #203241 by snowgoer540
Replied by snowgoer540 on topic Hypersensing questions
From the Plasma Primer:
We used a 15W Mean Well HDR-15 Ultra Slim DIN Rail Supply 24V DIN rail based isolated power supply.. This is a double insulated Isolation Class II device that will withstand any arc voltage that might be applied to the terminals.
Here's a link to one in the states (no idea where you are):
www.amazon.com/Meanwell-HDR-15-24-Power-...l%2Caps%2C202&sr=8-6
I didn't understand the importance of using a double insulated class 2 power supply at first. It can not have a path to ground, it must be floating.
22 Mar 2021 18:17 #203275 by bevins
Yeah, thanks, I ordere a meanwell also.
Rodw, will a 1/2watt 24K resistor on the ohmic schematic instead of 5 watt do from the that pulls down the 24v and connects to the -IN on thcad?
I cannot find the 24K 5 watt anywhere. mouser, didgikey, amazon, not in stock anywhere....
22 Mar 2021 18:30 - 22 Mar 2021 18:50 #203277 by PCW
Replied by PCW on topic Hypersensing questions
20K to 30K should work about the same (approximately 1ma sense current)
25K or 22K are much more common than 24K
5W is important in case of accidental short of the probe to the plasma voltage
(a 1/2W 200V max resistor might explode)
BTW Digikey does have a 24K 5W resistor:
www.digikey.com/en/products/detail/te-co.../ROX5SSJ24K/10231946
Last edit: 22 Mar 2021 18:50 by PCW.
22 Mar 2021 19:56 #203286 by rodw
Replied by rodw on topic Hypersensing questions
Yeh thats the one. Authoritave link here www.meanwell-web.com/en-gb/ac-dc-ultra-s...dr-15-24%23hdr-15-24
But when I looked it was readily available in all markets. I use RS Components and Element14 (Farnells) who both list it.
I ended up using 5 x 4.7k 1 W resistors in series (23.5k 5 W total) becasue I could buy them locally.
There is nothing accidental, the torch voltage shows up as a full scale reading of the THCAD whenever its cutting. Thats why we use the HDR-15-24 with the THCAD as both are rated to 500 volts.
  • snowgoer540
  • Moderator
  • Moderator
22 Mar 2021 20:24 #203288 by snowgoer540
Here's a link to the one I used from Mouser: www.mouser.com/ProductDetail/Vishay-Dale...erfnrke6gR%2Fw%3D%3D
99 in stock :)
23 Mar 2021 12:23 #203384 by bevins
Yeah I got them coming. Thanks
At fiurst gl;ance they wre Out of stock wherever I looked.
23 Mar 2021 12:35 #203387 by bevins
I ordered the DR-15-24 same except not thin line. Still class II isolation and power supply.
23 Mar 2021 12:37 #203388 by bevins
I am goi8ng to test it with the float switch as the probe then try the ohmic3 sensor version.
23 Mar 2021 20:52 #203431 by rodw
Interesting. Aside from availability, I wanted to know what you got for the extra $. I had a look at the specs. the DR-15-24 has less output derating once the ambient temp goes above 50 deg C. That was about all I cold see.
Plasmac supports both ohmic sensing and float switch input at the same time so I would do both right at the beginning.
Time to create page: 0.550 seconds
