THCAD
- phillc54
- Thank you received: 2100
20 Apr 2020 03:53 #164808
by phillc54
THCAD was created by phillc54
@tommylight
Tom, have you successfully run a THCD into a parport?
If so would you mind sharing the connections and settings, I would like to add them into the docs.
- Thank you received: 7504
20 Apr 2020 05:38 #164814
Replied by tommylight on topic THCAD
Yes, i was just searching for it.
20 Apr 2020 06:16 #164819
Found it, it's in the torchud.hal.
- phillc54
20 Apr 2020 06:46 #164821
by phillc54
Replied by phillc54 on topic THCAD
Thanks Tom.
Next question.
Is the Mesa THCAD the only current way of getting a plasma voltage into LinucCNC in realtime.
Next question.
- Thank you received: 4154
20 Apr 2020 07:00 #164824
In practice yes. The 7i76e has some analog inputs but not really designed for plasma and nowhere near as accurate. I think some of the mesa cards may have a more accurate A/D converter option but I'm not sure if they work with linuxcnc.
I am not aware of nay A/D converters for Linuxcnc.
Replied by rodw on topic THCAD
Thanks Tom.
Next question.
20 Apr 2020 07:02 #164825
LM331 is an option for DIY but very limited, it is also a voltage to frequency converter but it can do 10Khz i think, needs a simple circuit and an opto coupler to isolate it form the plasma side.
Anything else and the THCAD will win anyway you look at it.
I do have those LM331 collecting dust here, but i got Mesa THCAD, one working on a machine and 4 on the way to me (quite a long way due to this CCP cr@p ).
On the DIY side, there are also arduino based THC and they do work, again quite limited, but usable for sure. Pressed for time as i have plenty of them also, and i do have ESP32, several of them, was thinking of using that (12 BIT analog inputs, several of them, WiFi, BT etc, 2 processors at 240MHz) to send data wirelessly to the PC but the lag would prove unusable and the HF/HV interference would drop the connection, most probably.
- phillc54
20 Apr 2020 07:06 #164827
by phillc54
I think the Arduino way would use serial and that would only be userspace wouldn't it.
20 Apr 2020 07:06 #164828
Well there is also Ethercat. There would be a n A/D converter available there. Pretty sure Grotius did it that way.
20 Apr 2020 07:07 - 20 Apr 2020 07:07 #164829
I can build one for about 10$, but i never did, i just buy Mesa and be done with it. Mesa THCAD has some sophisticated isolation stuff in there, and having 1MHz bandwidth is just the icing and the cherry on the cake.
Any voltage to frequency converter will do, but properly separating them from the plasma is another subject entirely.
Last edit: 20 Apr 2020 07:07 by tommylight. Reason: typos
- phillc54
20 Apr 2020 07:10 #164832
by phillc54
I am looking at some document changes and I want to mention some practical options for users.
Time to create page: 0.254 seconds
