THCAD
  • phillc54
  • phillc54's Avatar Topic Author
  • Platinum Member
  • Platinum Member
20 Apr 2020 08:53 #164808 by phillc54
THCAD was created by phillc54
@tommylight
Tom, have you successfully run a THCD into a parport?
If so would you mind sharing the connections and settings, I would like to add them into the docs.
  • Moderator
  • Moderator
20 Apr 2020 10:38 #164814 by tommylight
Replied by tommylight on topic THCAD
Yes, i was just searching for it.
  • Moderator
  • Moderator
20 Apr 2020 11:16 #164819 by tommylight
Found it, it's in the torchud.hal.
  • phillc54
  • Platinum Member
  • Platinum Member
20 Apr 2020 11:46 #164821 by phillc54
Replied by phillc54 on topic THCAD
Thanks Tom.
Next question.
Is the Mesa THCAD the only current way of getting a plasma voltage into LinucCNC in realtime.
20 Apr 2020 12:00 #164824 by rodw
Replied by rodw on topic THCAD
Thanks Tom.
Next question.
In practice yes. The 7i76e has some analog inputs but not really designed for plasma and nowhere near as accurate. I think some of the mesa cards may have a more accurate A/D converter option but I'm not sure if they work with linuxcnc.
I am not aware of nay A/D converters for Linuxcnc.
  • Moderator
  • Moderator
20 Apr 2020 12:02 #164825 by tommylight
LM331 is an option for DIY but very limited, it is also a voltage to frequency converter but it can do 10Khz i think, needs a simple circuit and an opto coupler to isolate it form the plasma side.
Anything else and the THCAD will win anyway you look at it.
I do have those LM331 collecting dust here, but i got Mesa THCAD, one working on a machine and 4 on the way to me (quite a long way due to this CCP cr@p ).
On the DIY side, there are also arduino based THC and they do work, again quite limited, but usable for sure. Pressed for time as i have plenty of them also, and i do have ESP32, several of them, was thinking of using that (12 BIT analog inputs, several of them, WiFi, BT etc, 2 processors at 240MHz) to send data wirelessly to the PC but the lag would prove unusable and the HF/HV interference would drop the connection, most probably.
  • phillc54
  • Platinum Member
  • Platinum Member
20 Apr 2020 12:06 #164827 by phillc54
I think the Arduino way would use serial and that would only be userspace wouldn't it.
20 Apr 2020 12:06 #164828 by rodw
Well there is also Ethercat. There would be a n A/D converter available there. Pretty sure Grotius did it that way.
  • Moderator
  • Moderator
20 Apr 2020 12:07 - 20 Apr 2020 12:07 #164829 by tommylight
Any voltage to frequency converter will do, but properly separating them from the plasma is another subject entirely.
I can build one for about 10$, but i never did, i just buy Mesa and be done with it. Mesa THCAD has some sophisticated isolation stuff in there, and having 1MHz bandwidth is just the icing and the cherry on the cake.
Last edit: 20 Apr 2020 12:07 by tommylight. Reason: typos
  • phillc54
  • Platinum Member
  • Platinum Member
20 Apr 2020 12:10 #164832 by phillc54
I am looking at some document changes and I want to mention some practical options for users.
Time to create page: 0.330 seconds
