Help with adding PlasmaC to base config + 7i76e
6 years 5 months ago - 6 years 5 months ago #167377 by Plasmaguy
That is the same error you had before and the solution mentioned by PCW, namely the filter does not accept the value of -1, it does accept 0 or 1. Encoder scale be be -1 or whatever you need it to be.
You really, really have to stop editing stuff at random, you are wasting a lot of time and nerves doing constantly the same errors while editing.
I literally just added the files I was told to add, exactly as given to me by phill. Once those files failed, I only edited what was obviously erroneous which is the hm2's. I left the -1's as phill sent to me. Am I supposed to follow these instructions or not? There is numerous contradictory instructions in this thread. 4 days after asking for help I still have no working plasmac.
Did you not also see there are other errors than the -1? There is also an error "input-07 was already linked to probe-in"...again another error on using a file directly as it was given to me.
Accusing me of "not bothered to read" "randomly changing things" etc is not true and is rather counterproductive IMO. I have only changed what I was told to change, perhaps I implemented the changes incorrectly based on my understanding but I am certainly not randomly changing things around. You also gave misinformation earlier in this thread about the encoder and were corrected by PCW...well I try to follow what he says and also that is wrong apparently..
Last edit: 6 years 5 months ago by Plasmaguy.
6 years 5 months ago - 6 years 5 months ago #167382 by Plasmaguy
Well now I correct the file from the -1's I was given by phill and I've changed them into 1's as advised by tommylight and earlier PCW and now I'm just getting the error that :
h2m_7i76e.0.7i76.0.0.input-07 was already linked to signal probe in. Now what am I doing wrong this time?
6 years 5 months ago #167383 by snowgoer540
Plasmaguy wrote: Well now I correct the file from the -1's I was given by phill and I've changed them into 1's as advised by tommylight and earlier PCW and now I'm just getting the error that :
Hard to say without seeing your config and hal files. Can you attach them?
6 years 5 months ago - 6 years 5 months ago #167384 by Plasmaguy
You can find them in phill's most recent post ...he provided the files which I copied and pasted into my machine.
6 years 5 months ago #167385 by tommylight
Plasmaguy wrote: h2m_7i76e.0.7i76.0.0.input-07 was already linked to signal probe in. Now what am I doing wrong this time?
Somewhere in the hal file that pin is linked to something twice, so you need to remove one of them.
Most probably probe-in and float switch that was added after ruining the configurator, so if you do have probe0in in hal, delete that line or just omit it by putting # in front of that line.
6 years 5 months ago - 6 years 5 months ago #167386 by Plasmaguy
If I do a quick search of the file for "hm2_7i76e.0.7i76.0.0.input-07" only 1 result comes up in the the phill hal file I used to replace my machine hal file with.
I assume I was supposed to replace the files I created with configurator with the files provided by phill in his most recent post.
The only edits I've done since replacing the existing 2 files were to replace the obviously erroneous "h2m" with "hm2" and to change the scales from -1 to +1.
Time to create page: 0.079 seconds
