Help with adding PlasmaC to base config + 7i76e
6 years 5 months ago #167231 by Plasmaguy
It's in the picture in this post. forum.linuxcnc.org/plasmac/39045-help-wi...i76e?start=10#167226
Something about encoder scale and encoder velocity.
6 years 5 months ago #167233 by phillc54
They should be like this:
setp hm2_7i76e.0.encoder.00.scale -1 setp hm2_7i76e.0.encoder.00.filter 1 setp hm2_7i76e.0.encoder.00.counter-mode 1 net plasmac:arc-voltage-in hm2_7i76e.0.encoder.00.velocity => plasmac.arc-voltage-in
6 years 5 months ago - 6 years 5 months ago #167236 by Plasmaguy
Here's my latest try after adding the
line to the end of the hal file.
Last edit: 6 years 5 months ago by Plasmaguy. Reason: add clarity
6 years 5 months ago #167237 by phillc54
The errors say:
hm2_7i76e.0.7i76.0.0.encoder.00
You should have:
You need to remove the extra "7i76.0.0." from all the encoder lines
The following user(s) said Thank You: Plasmaguy
6 years 5 months ago - 6 years 5 months ago #167273 by Plasmaguy
Here I edited the base hal:
Here is configurator:
Here is the most recent error message:
Any ideas ?
Last edit: 6 years 5 months ago by Plasmaguy. Reason: uploaded wrong photo
6 years 5 months ago #167279 by PCW
as the message says -1 is invalid for a bit parameter
valid values for bits are 0,1 or true,false
Time to create page: 0.200 seconds
