Help with adding PlasmaC to base config + 7i76e
6 years 5 months ago - 6 years 5 months ago #167198 by Plasmaguy
You would not use the A hal pin on the encoder for a THCAD,
but rather the encoder velocity signal:
hm2_7i76e.0.7i76.0.0.encoder.0.velocity
Sec 27 of the plasmac manual refers to adding
setp hm2_7i96.0.encoder.00.scale -1
setp hm2_7i96.0.encoder.00.filter 1
setp hm2_7i96.0.encoder.00.counter-mode 1
for my THCAD10 somewhere in the base machine hal file. Just at the bottom of the file is okay?
I pasted to the bottom of my working base file:
Now upon launching the file created in configurator I get:
What do I do from here?
If it makes any difference I'm running the Mint .iso I downloaded from Linuxcnc package repos for Mint 19.x Ubuntu 18.04 aka Bionic Beaver & Mint ISO .
Last edit: 6 years 5 months ago by Plasmaguy.
6 years 5 months ago #167199 by phillc54
You have:
setp hm2_7i96.0.encoder.00.velocity
It should be:
The following user(s) said Thank You: Plasmaguy
6 years 5 months ago #167208 by Plasmaguy
Here as you can see I updated the base file but I'm still getting errors.
6 years 5 months ago #167212 by phillc54
I think they need to be:
setp hm2_7i76e.0.7i76.0.0.encoder.00.scale -1 setp hm2_7i76e.0.7i76.0.0.encoder.00.filter -1 setp hm2_7i76e.0.7i76.0.0.encoder.00.counter-mode 1 arc-voltagein should go to hm2_7i76e.0.7i76.0.0.encoder.00.velocity
6 years 5 months ago - 6 years 5 months ago #167219 by Plasmaguy
Okay I edited my base hal file so this is now at the bottom
and then run configurator
I still get errors:
I'll go ahead and try to attach my config files:
File Name: new2_connections.hal
File Size:1.51 KB
File Name: _original_...hine.ini
File Size:3.99 KB
File Name: _original_...hine.hal
File Size:10.13 KB
File Name: new2.hal
File Size:10.33 KB
File Name: new2.ini
File Size:8.73 KB
6 years 5 months ago #167220 by phillc54
Maybe it is just:
hm2_7i76e.0.encoder.00
I don't have one handy and am just guessing...
You can verify pin names in the menu Machine > Show Hal Configuration > Pins >
You will need to comment out those error lines so LinuxCNC starts
Time to create page: 0.154 seconds
