Another Valid Arc Lost Post
6 years 5 months ago #167372 by PurduePete
I was able to get it working last night with adjusting the low pass filter. I'm going to keep playing with it a bit but happy with the results. Got through an entire cut now. This does mean I'm not using the arc ok from the plasma cutter. May revisit down the road but I've got some jobs that need to be cut right away.
Thank you guys for the help.
6 years 5 months ago - 6 years 5 months ago #167433 by phillc54
Mode 1 means you are using Arc OK which is what you should use if your machine has it.
Edit: sorry, I read that as a question. I think I'm losing my mind...
Last edit: 6 years 5 months ago by phillc54.
Time to create page: 0.265 seconds
