- Thank you received: 4153
phillc54 wrote:
I would think that if a reasonable quality plasma cutter thought that the arc was lost it would ensure the arc was turned off.Just remember that if your plasma cutter decides the arc is lost, its going to cut the arc regardless of any synthesised arcOK signal
Can you post a screenshot of your Config panel and your Run panel.
Thats what I said, "cut the arc" ie turn it off.
phillc54 wrote: [
So what is the issue then?
Yes, I have seen them written often.You know my views on this.
I don't know of any one here who does think like that but I also don't think that soft Arc OK is as much of an issue as you say.The plasma manufacturer provides a mechanism to tell the CNC controller the arc has been lost (and when a valid arc has been established). Where this signal exists, it makes no sense to bypass it. Surely there is no user on this forum who honestly thinks they know more than Hypertherm about Plasma cutting?
phillc54 wrote: Check Arc Fail Timeout in the Config Panel
linuxcnc.org/docs/2.8/html/plasma/plasma...de.html#config-panel
THC Delay works identically for all modes.
EDIT: Set Arc OK High really high until you tune it in.
