setting up thcad
- Aaron3309
09 Jun 2020 00:26 #170733
by Aaron3309
Replied by Aaron3309 on topic setting up thcad
50 to 1 voltage divider from the hyper therm unit. I dont know how to zip the files i tried to follow a tutorial online just now and was unsuccessful, are there specific files from m config that you need?
- phillc54
- Thank you received: 2100
09 Jun 2020 01:05 #170736
by phillc54
Replied by phillc54 on topic setting up thcad
If you right click on the directory you should be able to compress
- Aaron3309
09 Jun 2020 01:32 #170740
by Aaron3309
hopefully i did tis right i had to create it from a terminal there was no option when i right clicked.
- phillc54
09 Jun 2020 01:42 #170742
by phillc54
I don't see this in your hal file:Put it in plasma2.hal after:
setp hm2_7i96.0.encoder.00.scale -1
setp hm2_7i96.0.encoder.00.filter 1
setp hm2_7i96.0.encoder.00.counter-mode 1addf hm2_7i96.0.write servo-threadPlease Log in or Create an account to join the conversation.
- Aaron3309
09 Jun 2020 10:28 #170800
by Aaron3309
ive tried to add it there multiple times however it will not let me. i have added it through the hal show function while i have my machine open. is there a different way to add it?
- phillc54
09 Jun 2020 10:31 #170801
by phillc54
What do you mean by "won't let you"?
Normally you would just edit the file with a text editor. (NOT a Windows one)
- Aaron3309
09 Jun 2020 12:30 #170828
by Aaron3309
I can open the file in a text editor but it won’t just let me save the file it creates a new file as a .txt. And I’ve tried to remove the old file and rename the new to the same name and .hal as the old but it won’t open
- phillc54
10 Jun 2020 00:37 #170896
by phillc54
Strange...
I have edited your file so try to copy this file to you directory. If you have any errors please post a screenshot of them.
- Aaron3309
10 Jun 2020 01:23 #170898
by Aaron3309
ok thank you! now i have added those lines temporarily while my machine was open and that when i get the wild voltage readings, could the way i was adding them in there been the problem? and with the machine sitting idle before any arc is initiated shouldn't it be reading 0 volts?
- phillc54
10 Jun 2020 01:28 #170900
by phillc54
Without knowing the actual errors you were getting, I don't know...ok thank you! now i have added those lines temporarily while my machine was open and that when i get the wild voltage readings, could the way i was adding them in there been the problem?
Yes, but you will need to restart LinuxCNC for those lines to take effect. The HAL files are only read once on startup.and with the machine sitting idle before any arc is initiated shouldn't it be reading 0 volts?
Time to create page: 0.106 seconds
