setting up thcad
- phillc54
- Thank you received: 2100
24 Jun 2020 23:58 #172650
by phillc54
Replied by phillc54 on topic setting up thcad
Your configuration looks OK. The only odd thing I see is that your Voltage Scale in the Config Panel is 0.000003, that is quite a bit lower than I would have thought. Although having said that I would have thought that the GUI would show a very low voltage.
What are the parameters you used to calculate that and did you use the online calculator ?
Do you have the THCAD jumpers set for UNIPOLAR and F/32?
I can't read the image you posted, by the time it is large enough for me to see it is too pixelated to decipher anything.
- Aaron3309
25 Jun 2020 00:51 #172656
by Aaron3309
Replied by Aaron3309 on topic setting up thcad
Sorry i was experimenting with the voltage scale and forgot to put it back, with the .0000003 it shows zero volts at idle but wont show more than maybe a volt when the torch fires. The real setting i use based on calculations is .01888574 which when used shows widely varying voltages even at idle.
- phillc54
25 Jun 2020 01:06 - 25 Jun 2020 01:15 #172658
by phillc54
At least you can see that I looked at your config
Did you check the jumpers?
I couldn't see any other obvious issues. It may be worth updating although I don't think that will resolve your problem.
Check and recheck your wiring, do you have a better image to post.
EDIT: I found another pic here but it is too pixelated as well.
Last edit: 25 Jun 2020 01:15 by phillc54.
- snowgoer540
- Thank you received: 907
25 Jun 2020 01:21 #172660
by snowgoer540
I had a similar problem with a THCAD 300. And it went away with switching to a THCAD 10. I’m not sure which card you’re using, But part of me wonders if there was something wrong with the 300 card. Mine varied like 30 volts at idle without any connection to the hypertherm.
Replied by snowgoer540 on topic setting up thcad
- Aaron3309
25 Jun 2020 01:54 #172663
by Aaron3309
I would tend to think there was a problem with the thcad card itself as well but the fact that even if i disconnect it from my 7i96 board there is no change leads me to believe its something else. i will start to go through the connections and wiring and i will chart out my connections better once i check them out.
- phillc54
25 Jun 2020 02:01 #172666
by phillc54
When you have LinuxCNC running if your Arc Voltage is jumping about with your plasma machine of then open a terminal and enter:
this will disconnect the 7i96 encoder from PlasmaC so if the voltage is now stable then the encoder is 'seeing' something.
halcmd unlinkp plasmac.arc-voltage-inthis will disconnect the 7i96 encoder from PlasmaC so if the voltage is now stable then the encoder is 'seeing' something.
- Thank you received: 5335
25 Jun 2020 02:05 - 25 Jun 2020 02:06 #172667
Replied by PCW on topic setting up thcad
if your encoder input is counting with nothing attached, that suggests
a wiring or noise issue or perhaps a faulty 7I96
Have you verified the you have a good 5V and the 7I96 and THCAD?
Do the encoder raw counts change if you have the 8 pin encoder plug
removed from 7I96 TB2?
Last edit: 25 Jun 2020 02:06 by PCW.
Time to create page: 0.094 seconds
