Plasmac Gcode documentation
- Thank you received: 4154
02 Jun 2020 10:39 #169794
Replied by rodw on topic Plasmac Gcode documentation
nah its more than that because you would not want to just take over the pin you want to share it with Plasmac, so you have to unlinkp, then or 2 your pin when you find the right one. I just found it a fairly complex exercise easy to stuff up (which I did!)
Mind you, my config is probably the most complex plasma table around and getting my hal files to play with plasmac was not trivial to start with..
- phillc54
- Thank you received: 2100
02 Jun 2020 12:05 #169797
by phillc54
Replied by phillc54 on topic Plasmac Gcode documentation
I guess it is a couple more but not too difficult and could all be in the postgui HAL file.
loadrt or2 names=thc-disable-or2
addf thc-disable-or2 servo-thread
unlinkp plasmac.thc-disable
net plasmac:thc-disable-0 thc-disable-or2.in0
net plasmac:thc-disable-1 your-thc-disable-pin thc-disable-or2.in1
net thc-enable-out thc-disable-or2.out plasmac.thc-disablePlease Log in or Create an account to join the conversation.
- Thank you received: 7501
02 Jun 2020 12:31 #169798
Replied by tommylight on topic Plasmac Gcode documentation
Hmm, me again, i still do not understand why would someone want to disable the THC for any reasonable reason, yet PlasmaC has 3 different ways of disabling it, and this is the fourth !!!
Icelander did try to explain why one would need it disabled, but i never got it as reasonable.
The most important feature on any plasma machine is the THC, so why on earth would someone disable it.
Consider me baffled!
02 Jun 2020 17:53 #169841
Well the most obvious is for kerf/void crossing which is what I'm working on..
One day, I will know the arc radius from within hal which might be another use case. (When I know how to get to the state tags data)
02 Jun 2020 17:56 #169842
Yes, that is a reasonable reason.
