Plasma no ARC OK and torch fires when machine is turned on
- luftlupus
- Thank you received: 16
13 Jul 2020 05:06 #174454
by luftlupus
Plasma no ARC OK and torch fires when machine is turned on was created by luftlupus
Hey everyone i am having an issue with my plasma cutter, i finished wiring and hooked it all up, now when i turn the plasma's power on the torch instantly fires by itself. Also i have no ARC OK light on the interface in plasmac. any advice would be appreciated.
THC also looks to be reading voltage so that's a bonus. the config folder is attached below if needed
- phillc54
- Thank you received: 2100
13 Jul 2020 05:13 #174455
by phillc54
Replied by phillc54 on topic Plasma no ARC OK and torch fires when machine is turned on
For the torch try reversing the wires to SPINDLE ENA- and SPINDLE ENA+
Are you getting a Transfer light on your machine?
- luftlupus
13 Jul 2020 05:33 #174456
by luftlupus
Replied by luftlupus on topic Plasma no ARC OK and torch fires when machine is turned on
- phillc54
13 Jul 2020 05:39 #174457
by phillc54
Maybe they output a voltage...
Disconnect the SPINDLE ENA- and SPINDLE ENA- and measure with a meter to see if the output a voltage when they get a torch on signal.
- luftlupus
13 Jul 2020 05:48 #174459
by luftlupus
is it normal for the torch to still fire without the cnc port connected aswell? would the ARC OK not lighting up on the interface have anything to do with it?
- phillc54
13 Jul 2020 05:51 #174460
by phillc54
No, I wouldn't think so. Is it a hand torch with the trigger stuck on?is it normal for the torch to still fire without the cnc port connected aswell?
You won't get an Arc OK until you have got a proper cutting arc, so you would need the torch to be at pierce height above some material.would the ARC OK not lighting up on the interface have anything to do with it?
- luftlupus
13 Jul 2020 06:01 #174462
by luftlupus
No its a full machine torch no trigger
That's good to know.
- phillc54
13 Jul 2020 06:05 #174463
by phillc54
Without a connection to 3 & 4 on the CNC port it shouldn't try to activate the torch.
- luftlupus
13 Jul 2020 06:07 #174464
by luftlupus
thats concerning, so maybe a machine issue?
- phillc54
13 Jul 2020 06:08 #174465
by phillc54
Kinda looks like it.thats concerning, so maybe a machine issue?
The following user(s) said Thank You: luftlupus
Time to create page: 0.298 seconds
