Plasma no ARC OK and torch fires when machine is turned on
- Thank you received: 7478
16 Jul 2020 00:01 #174787
Replied by tommylight on topic Plasma no ARC OK and torch fires when machine is turned on
No need to send it back, it can be opened and the pins can be moved to other places.
Check on the machine what pins are used, the ones with contacts inside and arrange the torch pins accordingly.
You might have to try several times by swapping them.
- Thank you received: 4149
16 Jul 2020 00:24 #174794
Replied by rodw on topic Plasma no ARC OK and torch fires when machine is turned on
That must have been the same on my Everlast. I opened the torch and cut the wire...... after a bit of time with a multimeter...
- luftlupus
- Thank you received: 16
16 Jul 2020 01:32 #174800
by luftlupus
Replied by luftlupus on topic Plasma no ARC OK and torch fires when machine is turned on
Just as easy to get them to fix it at no cost to me, As i have a fair bit of other work on.
Time to create page: 0.962 seconds
